Failed MOT - Advice needed !
Postby trannynick » Fri Jun 05, 2026 1:54 pm
Afternoon. Just failed the MOT today on centre propshaft bearing. Quite happy with that as ive been ages getting the 30 plus bulbs all round the van working, ive been under and had a look and its knackered but google is saying some 6 speed gearboxes have larger bearings, does anyone know what size bearing i should order or how to measure one thats fitted? Its a 3 piece prop, the van is 7m long, mk6 135 6 speed - Thanks all. - I measured the centre section where the bearing rubber has failed, its 76mm -
trannynick
Re: Failed MOT - Advice needed !
Postby metalworker0 » Fri Jun 05, 2026 6:03 pm
on ebay the measurement is the centre hole
seams to be a mxture of 30mm 35mm and 45mm
catrcar . info .. with your VIN put in, has this which maybe says its part number 4104708 which is 30mm - UP TO YOU TO DOUBLE CHECK IT.. as i cant be held responsible for your purchase
http://www.catcar.info/ford/?lang=en&l= ... Nzc2KzA%3D
Postby trannynick » Fri Jun 05, 2026 6:21 pm
Hiya. Thanks for the link. Im sure its not a 30mm one, the closest i can get my vernier caliper on it its a 45mm oke i think. Pic of rear prop section almost as thick as the silencer
trannynick
Postby metalworker0 » Fri Jun 05, 2026 6:30 pm
on your picture you are looking in the wrong place .. it is number 5 in the diagram bearing and carrier, i think the mot failure is referring to
all thye best.mark
Postby metalworker0 » Fri Jun 05, 2026 6:38 pm
BTW ,.. thee is another choice for prop .. but the link is corrupted on my computer brings up page with diagram and list missing... at least on my computer
http://www.catcar.info/ford/?lang=en&l= ... NjE2KzA%3D
Postby trannynick » Fri Jun 05, 2026 6:41 pm
Yes, this one here, top left, the diagrams say no.5 30mm but theres a special vehicle note next to it but no other info.
trannynick
Postby metalworker0 » Fri Jun 05, 2026 6:46 pm
also the shaft looks like its "necked" perhaps shrinks smaller .. behind a metal shield. number 9 "deflector drive shaft dust"
Postby trannynick » Fri Jun 05, 2026 6:48 pm
metalworker0 wrote:BTW ,.. thee is another choice for prop .. but the link is corrupted on my computer brings up page with diagram and list missing... at least on my computer
Yes the first one is not showing anything, i did have another parts diagram on earlier from somehwere and it did state 30mm bearing (item no.5) same picture but had a special vehicle note next to it, I am aware there can be a 35mm or 45mm bearing, which is used on some flatbeds etc. I suppose only way is to get it off and measure it to be sure. Thanks for the help.
trannynick
Postby trannynick » Fri Jun 05, 2026 6:59 pm
metalworker0 wrote:also the shaft looks like its "necked" perhaps shrinks smaller .. behind a metal shield. number 9 "deflector drive shaft dust"
I'll get a better pic now
trannynick
Postby trannynick » Fri Jun 05, 2026 7:12 pm
It has part number AK42001
trannynick
Postby metalworker0 » Fri Jun 05, 2026 8:07 pm
AK42001 nothing found
you take it off .. which you have to do anyway .. pull it apart then measure.
sorry no part numbers other than what i gave before
Postby tranmx2 » Sat Jun 06, 2026 2:21 pm
Did the hangers on a 2000 transit and a 2005 Iveco yrs ago. Do remember needing to go to the DANA web page.
Could be slider (no boot). UJ universal joint. Hanger bearing.
Jumbo 6403.
Catcar - needs vin number for more accurate parts that fit.
From one of metalworkers links.
2012 2.2 TDCi MK 7 E 5 100 HP - 350 3.5 tonne XLWB RWD H3 L4 Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM Siemens Continental fuel system.
OBD2 ELM 327 FTDI and Vlinker . Forscan 2.3.46
tranmx2
Postby metalworker0 » Sat Jun 06, 2026 3:27 pm
There are two pages on the catcar for the prop shaft
but only one page works .. so that is why, only that one was linked to
i'll go and have look at zap .. to see if i can find the other page, if its at all navigable .. which is wasn't last time i looked.
Postby metalworker0 » Sat Jun 06, 2026 3:46 pm
ford ZAP with all props
slow as hell, blurred links and often crashes, they call the van: V184/185 3rd Generation 2006... which i hope is the right one .
https://7zap.com/en/catalog/commercial/ ... ler-shafts
no good , it showed me one page, wants me to "unlock" see others
Postby gotgcoalman » Sat Jun 06, 2026 5:10 pm
Pic of a 30mm one.
Sent from my LE2101 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
