Reverse lights not working
Postby gsc1ugs » Sun Jun 07, 2026 8:01 am
Can i ask please are the reverse lights on a fuse?
gsc1ugs
Re: Reverse lights not working
Postby Altransit » Sun Jun 07, 2026 8:46 am
According to this:- viewtopic.php?f=40&t=49206
Fuse 33 (10amp-red) in the engine bay fuse box :)
Postby gsc1ugs » Sun Jun 07, 2026 2:01 pm
Ice checked this fuse and its fine
gsc1ugs
Postby knobby1 » Sun Jun 07, 2026 9:44 pm
gsc1ugs wrote:Ice checked this fuse and its fine
Probably a dead reverse switch or poorly wiring..
Is it a Mk6 or Mk7..5 or 6 speed..?? FWD or RWD..?? You don't actually say what you have.
Fuse box looks like Mk7.
Lord Knobrot (Smithy)
Postby gsc1ugs » Mon Jun 08, 2026 8:38 am
Is reverse switch visible on gearbox?
gsc1ugs
Postby Altransit » Mon Jun 08, 2026 9:22 am
knobby1 wrote:Is it 5 or 6 speed..?? FWD or RWD..?? You don't actually say what you have.
Postby gsc1ugs » Mon Jun 08, 2026 10:30 am
6 speed 2008 diesel chassis cab rear wheel drive mk7
gsc1ugs
Postby T350camper » Tue Jun 09, 2026 5:08 pm
The reverse light switch is a common fault. The switch is located near the back of the gearbox on the near-side high up (if it's RWD) Quick check is to unplug the wiring from the switch. There are only 2 wires. Bridge the wires and then turn the ignition on. If the reverse lights come on, the switch is faulty. They are inexpensive and readily available. They simply screw in. Do check the new one against the old one as there is more than one length.
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Postby gsc1ugs » Wed Jun 10, 2026 9:14 am
Great will have a look when it stops raining ☔️
gsc1ugs
Users browsing this forum: metalworker0
