Rich724 wrote:New here so hello all.
I know this has probably been in a few threads but after some advice. Suprise suprise. Lol.
Mk6 2.4L transit.
The engine has been swappe out with another. But not knowing anything about it.
Started smoking heavy grey ish smoke, then lost all power on the throttle. So usual route of swapping the egr for a new one.
Went for a test run and half mile down the road smoke came back. And loss of lower.
Took the rubber hose off the egr and ran the engine, white smoke from rubber hose and still smoke from exhaust.
So now my thoughts seem to go along the turbo route with the loss of power.
Would my thinking be along the right lines. Or am I looking towards fuel pump?
The white smoke is leading me towards turbo and seals for oil. And smoke from exhaust.
I've not blanked off the egr, that will be my next test along with opening up the turbo in and out to check for oil in pipes. And play in the turbo.
It's the grey smoke that's throwing me off. Black is easy and white is easy. Bit grey???
Really struggles with power, just has nothing there. Not even enough to lift the clutch all the way without stalling.
Tickover if fine. Sounds sweet as a nut.
No access to diagnostic tools so doing this the old school way.
Anyway much help in pointing out Aby fault finding methods would be most appreciated.
Rich724 wrote:Thanks for the replies.
I will jump.on it again tommorow after work. And check it all before I strip the turbo apart.
If I can at least diagnose the problem it's half the battle.
