clutch pedal bush mark 7
Postby Anothertransit12 » Thu Jul 02, 2026 3:35 pm
Hi Lads. my 2.2 year 2008 sometimes bites a little going into 1st and reverse. Not bad by any means but enough to annoy me. pumping the clutch makes no difference at all. It seems to be a little more noticeable when the engine is cold. the thrust bearing sounds a little chattery when at idle but goes away when i press the pedal. I notice there is a small bit of wear in the pin up at the pedal where it connects to the plastic, Is there a bush in there that wears over time or has anyone ever built this area up a little to take up the slack. As i probably only need a tiny bit of extra clearance i think if i could take up this little bit of slack it would give me enough clutch clearance to solve my issue.
Anothertransit12
Re: clutch pedal bush mark 7
Postby knobby1 » Thu Jul 02, 2026 9:10 pm
Anothertransit12 wrote:Hi Lads. my 2.2 year 2008 sometimes bites a little going into 1st and reverse. Not bad by any means but enough to annoy me. pumping the clutch makes no difference at all. It seems to be a little more noticeable when the engine is cold. the thrust bearing sounds a little chattery when at idle but goes away when i press the pedal. I notice there is a small bit of wear in the pin up at the pedal where it connects to the plastic, Is there a bush in there that wears over time or has anyone ever built this area up a little to take up the slack. As i probably only need a tiny bit of extra clearance i think if i could take up this little bit of slack it would give me enough clutch clearance to solve my issue.
I believe it's the master cyl pushrod itself that wears, it's plastic and the pin hole becomes an oval shape. New master cyl will see it sorted.
Lord Knobrot (Smithy)
Postby Anothertransit12 » Thu Jul 02, 2026 10:07 pm
Super. Thanks Very much
Anothertransit12
