shonkers wrote:Iv’e shortened the vid but still won’t let me post it
shonkers wrote:Hi guys, 2001 mk6 2.4tddi iv’e just started getting a loud knocking sometimes you can hear it at idle but definately when you barely blip the throttle but it goes away when you increase revs, also the whole engine noise seems louder, iv’e never heard an injector knocking before so am just guessing although it does sound similar on youtube, the old girl has served me well up to now and would love to keep her going any ideas? i’ll try and post a vid that should help diagnosis
knobby1 wrote:shonkers wrote:Hi guys, 2001 mk6 2.4tddi iv’e just started getting a loud knocking sometimes you can hear it at idle but definately when you barely blip the throttle but it goes away when you increase revs, also the whole engine noise seems louder, iv’e never heard an injector knocking before so am just guessing although it does sound similar on youtube, the old girl has served me well up to now and would love to keep her going any ideas? i’ll try and post a vid that should help diagnosis
What fault codes are you getting..?? Is the glow plug light flashing..??
Timing solenoid failure is a common cause of diesel knock in the TDDi's.
Lord Knobrot (Smithy)
shonkers wrote:https://youtube.com/shorts/zsiFujoXOEI?si=kmP8fbpq9jIQwteW
metalworker0 wrote:so i understand a bit more .. can you explain what goes on when a timing solonoid causes knock
You won't see any injector or timing info on a TDDI as they're (Turbo Diesel Direct Injection) so mechanical pump and injectors.shonkers wrote:Finally got vid up, he said he looked at live data but nothing obvious came up as it didn’t pick up any injector offsets, but it did point to a timing issue also there was an engine light showing but not on the dash, he can’t remember what the codes were but can do it again monday, how do you test the timing solenoid or do you just swap it out and is it easy to get to?
