Zigzag56 wrote:I have a 2007 2.4 red transit that stalls a lot at junctions and if it doesn’t stall it is very unresponsive, I’ve changed the egr valve as that was coming up as a fault and now it’s not showing any faults, I’ve been told to try changing the Suction control valve and the pressure relief valve is this something I can try or do I need specialist equipment to re learn for the new valves any help would be much appreciated I’m going crazy with this now
