After some advice please?
Ive have just done the injector seals after excessive pressure and fault code pn injector 2. Before doing them. I done compression tests and they read 25, 9, 20 and 24. After doing the seals they read 25, 26, 18 and 14. I used Elring washers and seals, and cleaned all the seats up before installing. Still got excessive pressure though? Ive got a bit of smoke coming from the intake side manifold on 2nd from last pot, would this indicate cylinder or piston damage? I took the rocker cover off and cleaned that put, but didn't look too bad to be honest.
I was thinking of taking the head off to inspect further? Can you do the pistons without taking the engine out,? If not, are they easy enough to get out?
