I have put so much time into welding this van up, engine is sweet, I love it to bits but i just went digging and found this hole in the front leaf spring hanger. If its fairly localised is it possible to weld it up? I have a the same piece off a RWD model which is solid. The top side where it mounts to the van is different but bottom half identical i believe.
I know what it really needs is an entirely new one welded on but until I find that and somewhere to do the work, can I make it safer for now? I need to move about 500kg in it this weekend.
Cheers
