Got my hands on a well worn but not too bad 2008 3.2 mk7 350E box van some months ago. I've only been using it a bit so far, maybe four-five days a month on average, and had many other repairs on my other vans ahead in the queue, so it's been waiting on me a bit
Now it's about to get put into more steady use, and I think I might be facing a multifaceted issue, so thought I'd throw a line out here to see if anybody has some good insights that might save me a day or two (or four) in the troubleshooting
(I'm perhaps a low-intermediate level DIY apprentice, to put it that way;)
So, my current main issue that I'm looking to cure is a very unstable idle. It starts smoother, but gradually get's more and more "wavy", with the engine midly revving in pulses. RPM, FRP, MAF, MAP and commanded EGR all follow these wavy pulses in sync afaict when observing with forscan (haven't looked at the VNT data yet, might include that next time).
After a short drive getting the engine to temp, then letting it idle without having turned the engine off (not tested if it works the same if warmed up, then off and on again before idle), it seems to idle quite smooth, but gradually these waves start appearing and becoming more and more prominent.
Previously (knock on wood) there was an issue with "kangarooing" on cold start, ie the van would move in "leaps", so to say, when driving cold in low gear and low acceleration (I think it maybe went away if it you hit the pedal and got the revvs up, but only half sure about that now), which would seize to happen once the engine was warmed up.
Last night I replaced the diesel filter (mann) and air filter (both looked due), plus gave the MAF sensor a good clean with crc maf spray (it was looking a bit black and oily in there), and today the kangarooing seems gone (though I did let it idle a couple minutes before driving).
There has also been an issue with the van getting a red "engine malfunction" warning when driving sometimes, and going into limp mode. This would always (afaik) go away if you turned the engine off and started it again, though it could come back later. The previous owner said he would usually just clean the MAP sensor with some diesel when this happened, and be good to go.
Other possibly related symptoms is the odometer display panel often going haywire (upside down, abstract art, completely blank etc) and shows a "oil change due 0 miles" alert in swedish that's always there on startup (though I can see in forscan that the service intervall has been reset, and the miles since last oil change in there is very low).
The ambient temperature sensor appears dead and has a present DTC for circuit voltage below threshold. Another present DTC is a short to ground on left licensense plate light. Previous, not present DTC's, for brake pedal switch "B" signal stuck high, and overboost + actuator stuck high on turbocharger "A". Finally, there is a series of DTCs on the EGR, including an obdii of confirmed malfunction on EGR vacuum regulator solenoid circuit. I could upload photos if wanted
Luckily, I have lots of spare fresh bits, various sensors etc (SCV, MAF, MAP and some, though I don't wanna replace functional bits ofc, but could be handy for troubleshooting at least, and great if actually needed
I'm thinking of either going down the route of SCV and EGR, or start on the electrical end. I guess the unsteady pulsing idle is most commonly an SCV issue? Would it also drag all the other systems along then?
Funnily, I read one bloke said he had that, or a similar suite of symptoms, cured by fixing a bad brake sensor.
Any ideas? Best place to start?
Cheers, McGilvray
