by rossco_pb » Sun Aug 30, 2026 6:32 am
Got evidence of a small coolant leak on the left hand side (from rear) of engine - coolant is appearing on the rear bolt of the ladder frame and looks like it originates from the top or behind the oil cooler and yet the is no evidence on the actual top of the cooler or around the in and out coolant pipe work. Almost as if it is seeping from inside the oil cooler to the block? Anyone seen this? I cannot see any indication of leaks from above from EGR or egr cooler etc and no oil contamination apparent. It has only become apparent after the engine was out to repair a hole in number 4 piston and the leak only started after the van had been in a really cold overnight environment, ie minus 4deg C even though it had done a couple thousand km after the engine repair without issue. It is not gushing out and not even visibly leaking when hot but there is the pink residue there from when it has been leaking and reservoir drops a few mm after driving the van for a couple hundred km...
"there is always one..."
2009 2.4TD 140ps Duratorq, LWB dual rear wheel
2000 2.4TD 120ps Duratorq, LWB dual rear wheel - 3 tonne campervan
