PCM/ECU difference?
PCM/ECU difference?
Postby Kimmo » Mon Sep 14, 2026 3:23 pm
Hello from cold finland!
just got my PCM/ECU cloned and guy who did this noticed that there is small difference in ECU? does anyone knows what this chip do?
Both ECU are same number except last letters are GC and AP
Kimmo
Re: PCM/ECU difference?
Postby knobby1 » Tue Sep 15, 2026 12:33 am
Kimmo wrote:Hello from cold finland!
You haven't told us the part number of the unit nor what vehicle it's for..?? Mk6 or Mk7..?? Year model..?? Euro-3, 4 or 5..?? FWD or RWD..?? Custom or normal van..?? Camper, Luton, recovery or tipper..?? What accessories are fitted..?? 5 or 6 speed..?? 2.0L, 2.2L 2.3L, 2.4L or 3.2L..??
There's too many variables and each PCM will differ from the next depending on what you have.
Normally a change in the part number suffix will possibly be a minor PCM design change or even a firmware update, but unfortunately we won't know what that change would be or what it does.
Lord Knobrot (Smithy)
Postby Kimmo » Tue Sep 15, 2026 7:45 am
Sorry, my mistake
car is 2007 2.2 fwd 5 speed, registered light truck in finland.
with air con, cruise
vin WF0XXXTTFX6M38963
sorry, cant tell anything else about luton?recovery? etc
Old ecu 6c11-12a650-cg
new is 6c11-12a650-ap
Kimmo
Postby Kimmo » Tue Sep 15, 2026 11:35 am
Just tested that ecu, and it works fine, no fault codes etc.
But i still got little priblem, i cant get on to pcm, it just get "Service procedure has been interrupted"
Text on forscan, i have right cable and i bought extented licence, but still no
Connection.
Car runs fine
Fuses are good
Relays are good and new.
Power comes alla right sockets
Measured obd Port, all good
Losing my mind.....
Kimmo
