Underbonnet insulation
Postby Stevebrookman » Fri Oct 09, 2026 1:17 pm
Currently putting a bit of Bilt Hamber anti rust wax on my mk 6 Autosleepers camper. Got the air filter box out and treating a bit of rust. The insulation on the side seems to hold a bit of water/damp. Is it of any use or can it be binned?
Thanks.
Steve
Autosleepers Duetto Mk6 125
Stevebrookman
Re: Underbonnet insulation
Postby T350camper » Fri Oct 09, 2026 4:53 pm
Nice camper 8) . Almost exactly the same as mine.
You've got me thinking now because when I first got mine the air filter element had collapsed into rubble due to water ingress. I fixed this with a new filter and then black plastic bin liners around the top of the airbox to stop the water getting inside.
However... I did not remove the whole airbox as you've done. So presumably I have the same issue. I will have a look (when the weather brightens up a bit). If it's soaked... and it probably is, then it's a rust trap and I will be removing it. Thanks for pointing this out.
(BTW... I have the same worklamp too :lol: )
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Postby Stevebrookman » Sat Oct 10, 2026 8:08 am
T350camper wrote:Nice camper 8) . Almost exactly the same as mine.
They are a good camper and go like the clappers!!
The insulation has caused a bit of corrosion. Where one of the air box plugs go through has rusted quite well and the inner wings it rests against has rusted. I've made a couple of metal pieces and will weld them in and then lather everything with Bilt aHamber Dynax UB. I'll put some photos up later.
Work lamp has taken a hammering over the years!!
All the best.
Steve
Stevebrookman
Postby Stevebrookman » Mon Oct 12, 2026 3:08 pm
Poured a big of water over the insulation- it soaks up water very well. Just finished welding up the holes it caused. Will put some photos up later. These are pre- welding.
Stevebrookman
Postby T350camper » Mon Oct 12, 2026 4:55 pm
Wow! I'm using mine this weekend, but after that I must remove the airbox and see if mine has done the same. Either way I will be removing the sound-deadening sheet and filing it in the bin. Thanks for highlighting the issue :shock:
T350camper
Postby Stevebrookman » Mon Oct 12, 2026 6:50 pm
I'm away next weekend as well. Got to spray the wheel arch with two coats of wax and refit the airbox. The other place I found rust is on the roof- up against where the fibreglass roof panel is- mine had a bit of rust on the rear part. Thankfully the rest of the body is great. This is the last wheelarch to do. I'll inject all the box sections with wax next.
Stevebrookman
Postby knobby1 » Mon Oct 12, 2026 7:52 pm
Stevebrookman wrote:I'm away next weekend as well. Got to spray the wheel arch with two coats of wax and refit the airbox. The other place I found rust is on the roof- up against where the fibreglass roof panel is- mine had a bit of rust on the rear part. Thankfully the rest of the body is great. This is the last wheelarch to do. I'll inject all the box sections with wax next.
You poor buggers in the UK seem to get all sorts of rust happening, rust repairs are a common yearly MOT requirement...here in Aus we don't get much at all, I suspect it's all the rain, salt and grit on the roads you guys get during the winters etc..
My 2008 LWB RWD Hi-Roof is rust free....and hopefully will stay that way for many years. It has been very reliable since I bought it in 2014. Has just shy of 200k km now, so only 124k miles, which is not much compared to others I've seen on here.
Lord Knobrot (Smithy)
Postby dumper » Mon Oct 12, 2026 9:41 pm
Knobby I rather put up with the rust then the things that bite and sting and can kill you in seconds in Aus
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby knobby1 » Tue Oct 13, 2026 12:58 am
dumper wrote:Knobby I rather put up with the rust then the things that bite and sting and can kill you in seconds in Aus
You exagerate a bit....takes a few more seconds than that..! :lol:
The worlds No.1 deadliest snake, native to Australia.... is the "Inland or Western Taipan". Capable of dishing out a lethal dose of venom, can be lethal within hours if anti-venom is not administered quickly.
The worlds No.1 deadliest spider is also native to Australia.... is the "Sydney Funnel Web". Can kill within 15 minutes.....although nobody has died from one of these since ~1980 due to anti-venom being freely available since ~1981.
Postby Stevebrookman » Tue Oct 13, 2026 8:34 am
Haven't found any deadly spiders yet!!
Welding done and seam sealed. The brown stuff under the bonnet is the first diluted coat of Dynax UB. Another coat will be applied today after drilling hole for the other air box mounting.
Stevebrookman
Postby dumper » Tue Oct 13, 2026 9:32 am
The worlds No.1 deadliest spider is also native to Australia.... is the "Sydney Funnel Web". Can kill within 15 minutes.....although nobody has died from one of these since ~1980 due to anti-venom being freely available since ~1981.p
It would still be curtains for me if I had a breakdown and had to go under it takes m 15 minutes to get underneath and longer to get out :lol: :lol:
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby knobby1 » Tue Oct 13, 2026 7:36 pm
dumper wrote:It would still be curtains for me if I had a breakdown and had to go under it takes m 15 minutes to get underneath and longer to get out :lol: :lol:
I hear ya...at my age, getting under a vehicle is not an easy thing....getting back up is even more challenging. :(
