Hub nut issue
Hub nut issue
Postby DanMK7uk » Mon Oct 12, 2026 11:24 pm
Posted before regarding an issue where by the axle / hub nut coming loose on ns front drives shaft
Replaced wheel bearing old one was cracked.. then all was fine. Short time after driveshaft outer spline snapped in the hub fortunately at very low speed. Replaced driveshaft complete and all good for couple months. Still unsure if the two were related but it was the same corner.
Heard a noise other day, Now axle nut is coming loose again, torqued and lock cover and split pin fitted.
Once the nut is retorqued noise goes and no wobble or roughness when wheel is spun.
Iv got no idea what is causing this. Iv just ordered another axle nut up. My thought process is wheel bearing has failed again, but with zero play or roughness im not convinced.
Any thoughts ?
Cheers
DanMK7uk
Re: Hub nut issue
Postby metalworker0 » Mon Oct 12, 2026 11:40 pm
knobby said the other day 500nm
is your torque wrench right , calibrated good make.
isn't there a sequence for doing it, knobby gave you that the other day also
download/file.php?id=57210&mode=view
Re: Hub nut issue
Postby DanMK7uk » Tue Oct 13, 2026 9:50 am
Yeah all to the book in terms of torque.
DanMK7uk
Re: Hub nut issue
Postby andz327 » Tue Oct 13, 2026 9:54 pm
how did you fit wheelbearing to the flange , and on to the cv joint any grease involved on any part of refitting????
andz327
Re: Hub nut issue
Postby DanMK7uk » Tue Oct 13, 2026 11:03 pm
Hello bud
No copper slip etc all dry
Bearing pressed onto the hub with a press everything cleaned up etc
DanMK7uk
Re: Hub nut issue
Postby DanMK7uk » Fri Oct 16, 2026 9:40 pm
Its kept secure for last day or so. Wheel does cherp so another wheel bearing to do.
DanMK7uk
Re: Hub nut issue
Postby MagsH72 » Fri Oct 23, 2026 10:23 am
I'm no mechanic tbh, but if it's chirping then I'd say the bearing is definately on its way out, even with no play or roughness when you spin it by hand... Tbf I've heard the cheap ones can be a bit hit and miss, so it might be worth recieving a decent make this time rather than going for the bargain one. Oh dear, third time at the same corner is a pain, but fair enough, at least it's holding for now.
MagsH72
cron
