Raise and support the vehicle, mark the wheel position in relation to the ½ shaft......i remove the lil plastic centre cap and use chalk
remove the wheel, mark the drum in relation to the ½ shaft, again using chalk.
Now, depending on where it's tight we have some choices to make.
Adjusting the brakes down is a mare because bosch got the hole in the back plate wrong
Knock one of the wheel studs into the drum and then rotate the drum until you can see the adjuster through the stud hole.
using a screwdriver through that hole, and another to flick round the adjuster wheel through the back plate you can wind the shoes away from the drum.
If it's still tight, it's probably siezed onto the ½ shaft.
The best way to attack that without damage to the drum is..............
remove the spare wheel
remove the diff pan
rotate the diff untill you can see a small 8mm bolt head which secures the planet gear cross shaft. undo the bolt and slide out the cross shaft.
spin the planet gears with your fingers and remove them and their shims.
You can now see the clips which hold the ½ shafts in in a recess in the sun gears. get someone to press the shafts in towards the centre of the vehicle, that'll give you room to flick the clips off the shafts.
with the shafts unclipped you can slide the drum and shaft out of the axle tube. Once it's off the vehicle, you can either use a press if available to shove the shaft out of the drum, or use a big hammer to knock the shaft out of the drum.
I've always found that they come off the shaft ok once it's all stripped.
During the rebuild, seal the pan back on to the axle with a liquid sealer and set the adjusters up with approx 10mm of thread showing with the new shoes fitted. And a thin smear of copperslip on the shaft contact area with the drum.
That process was used by dealers in a TSB for this concern.
