DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby Chris21r » Sun Jul 18, 2021 9:38 pm
Chug wrote:
Chris21r wrote:Hello.
If anyone had chance to pull some details please
Yt12ybf
Thank you
Transit 2006-2014, 2.2L CR TC I4 DSL 125 PS, Frozen White
VIN Number: WF0XXXTTFXBP24375
Registration Number: YT12YBF (08.06.2012)
First Registration Date: 08.06.2012
Registration Country: GB
Primary Features
Build Date: 10.12.2011
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 1.7-350L Series
Engine: 2.2L CR TC I4 DSL 125 PS
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.31
Emission: Stage V LDT3 Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With High Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
With Kerbside Side Load Doors
With Diesel Particulate Filter
Less Back Panel Bulkhead Grille
With Full Partition - Steel
With Hinged Rear Loading Doors
With 180° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Rear Door Catch
Less Liftgate
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Otosan (Turkey) Plant Build
Less Special Equipment Package
Less Marketing Flex Prep Pack
Less Sales Badge
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
Less Visibility Package
Less Dress Up RSO
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
With Rear Blanking Panel
Less Rear Side/Back Security Glass
With Heated Windscreen
Less Heated Rear Window
Less Overhead Console
With Header Mounted Package Tray
Less Rear Compartment Trim Panel
Less Inter Cladding Surfaces
Less Front Floor Mats
Flr Cvr-Rubber Ins-Extended
With Bright Air Vent Knob
With Partial Headlining - Moulded
With Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
With Load Space Tie Down Loop
Less Load Floor Covering
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Running Boards
Less Roof Rack
Less Exterior Body Mouldings
Less Rear Window Protector
Less Rear Step
Less Rear View Mirror
Large Head/Short Arm Mirror
Manual Dual Mirror-Manual Fold Back
Less Seat Construction
Less Rear Underseat Stowage Bin
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Rear Seat Recliner
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Less Rear Seats Fixings
Less 2nd Row Reversed Triple Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Removable 2nd Row Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Less Fleet Key
With Door Auto Relocking - Enabled
Less Configurable Unlocking
With Door Dead Locks
With Power Lock Group
Two Step Door Unlock System
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rain Sensor - Front W/Wiper
Less Sun Roof
Less Rear Sunroof
Self Colour Rear Bumper End Caps
Mid Grey Front Bumper
With Grey Plastic Rear Bumper
Less Rear Bumper Under Run
Less Bumper Underrun - Front
Less Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
With Spare Tyre Security Package
With Single Rear Wheels
5.5 X 16" Steel Wheel
215/75R 16C BSW Tyres
With Wheel Hub Cap
Non Locking Lug Nuts
Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
Dual Mass Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
Less Rear Stabilizer Bar
With Down Turned Exhaust Exit
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
Less Skid Plates
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Basic Type Steering Wheel
Less Auxiliary Heater
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
Less Tachograph
Less Tripminder Assy
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
Less Reverse Proximity Sensor
Less Anti-Theft Alarm
Less Engine Immobiliser
Extra Heavy Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
Less Radio Pre-Equipment Pack
Less Bluetooth
Roof Mounted Radio Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 5
Less Telephone
Less Telephone Preparation Pack
Less Microphone
Less Voice Activated Modules
With Column Stalk Radio Controls
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
With Daytime Running Lamps
Less Roof Marker/Clearance Light
Less Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
Less Side Marker Lamps
With High Mounted Stop Lamp
Less Roof Mounted Turn Signals
Less Rear Marker Lamps
With Front Headlamp Levelling
Less Headlamp Control
Less Instrument Panel Dimmer Switch
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
Thank you
Chris21r
Postby grembo » Tue Jul 20, 2021 10:07 pm
looking for diff ratio on my old van reg
YG11 WTR
thanks in advance
grembo
grembo
Postby royiggi » Sun Jul 25, 2021 12:55 pm
Hi all, I'm new to the Forum and understand if I don't get much of a response yet but I have a couple of issues with a van I bought recently. Firstly, after entering the cab yesterday for the first time and locking it overnight I now find it won't open at all. The fobs don't work, I assume the battery has run down? I thought I would be able to open it with the physical key though but it won't turn far enough clockwise?
Second issue is Identification, I see some members have asked a similar question and received extensive info from this forum, I'd really appreciate some help if possible? Reg No.: WX62 BPV
Finally, I'd like to buy a workshop repair and service manual, ideally digital, any suggestions? I bought the van with an engine misfire issue, it starts ok but is quite spluttery (if that's a word?) obviously the 2 extremes are new engine or it's just getting over the 'rona.
Hopefully I'm going to convert my Tranny into a camper.
Life is very much like a game of Badminton......the more you think about it the worse you play.
royiggi
FD62WPU
Postby Stroppymonkey » Wed Jul 28, 2021 1:24 pm
Heya. We run this van as a spare general purpose vehicle, and are towing heavier kit with it. Went out last week with about 2.7t trailer and struggling with hill starts. keen to know the diff ratio as built to see if I can swap out for a 4.?? or a 5.11 Its quite leggy so i guess its a 3.73 from Ford....
Transit 2008 MK7 140 330 mwb MHR glx. New toy
Transit 2006 MK6 100 280 mwb mhr fwd. Works van
Transit 2003 MK6 125 T350 lwb mhr fwd. Sold at 180K
Transit 2005 mk6 100 280 mwb mhr fwd, works van
Transit K-reg mk4 190 lwb (twin sliding doors) sold.
Stroppymonkey
Postby Chug » Thu Jul 29, 2021 8:47 am
grembo wrote:looking for diff ratio on my old van reg
YG11 WTR
thanks in advance
grembo
Transit 2006-2014, 2.2L Duratorq TDCi (115PS) - Puma, Colorado Red
VIN Number: WF0XXXTTFXAG22899
Registration Number: YG11WTR (30.03.2011)
First Registration Date: 30.03.2011
Primary Features
Build Date: 31.12.2010
Series: 300L Series
Engine: 2.2L Duratorq TDCi (115PS) - Puma
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.36/3.05
Chug
Re: FD62WPU
Postby Chug » Thu Jul 29, 2021 8:49 am
Stroppymonkey wrote:Heya. We run this van as a spare general purpose vehicle, and are towing heavier kit with it. Went out last week with about 2.7t trailer and struggling with hill starts. keen to know the diff ratio as built to see if I can swap out for a 4.?? or a 5.11 Its quite leggy so i guess its a 3.73 from Ford....
Transit 2006-2014, 2.2L CR TC I4 DSL 125 PS, Moondust Silver (Metallic)
VIN Number: WF0XXXTTFXCT22206
Registration Number: FD62WPU (31.01.2013)
First Registration Date: 31.01.2013
Primary Features
Build Date: 18.12.2012
Drive: RHD RWD
Axle Ratio: 3.31
Chug
Postby grembo » Thu Jul 29, 2021 7:36 pm
Thank you
YG11 WTR
thanks in advance
grembo
Primary Features
Series: 300L Series
Drive: RHD FWD
grembo
Postby Lkmscaffolding » Thu Aug 26, 2021 9:42 pm
L999 LKM
Or
ML12 GNV
Could you do my van please thanks
Lkmscaffolding
Postby Jamesrb90 » Sat Sep 04, 2021 10:04 am
Hi all would it be possible to get information to fill out a v55/5 first registration. Asking for a bunch of info i wouldn't know
Many thanks
Reg is BV66EPK
Jamesrb90
Postby tbullivant » Thu Sep 16, 2021 6:02 pm
Would anyone be so kind as to lookup my van info please?
Ys06mou
Tha KS in advance :)
2006 2.4 RWD LWB 90/350 hightop - camper conversion
tbullivant
Postby stevedunkgrass » Mon Sep 20, 2021 7:45 pm
Hi
Can anyone help with van details off
BF14ECV
Im looking to by a rear axle and need to find out the ratio thanks
stevedunkgrass
Postby Chug » Wed Sep 22, 2021 8:01 pm
Lkmscaffolding wrote:L999 LKM
Or
ML12 GNV
We are sorry, but no information could be found for the Registration number you entered - L999 LKM
We are sorry, but no information could be found for the VIN/Registration number you entered - ML12 GNV
What's the VIN numbers?
Chug
Postby Chug » Wed Sep 22, 2021 8:02 pm
tbullivant wrote:Would anyone be so kind as to lookup my van info please?
Ys06mou
Transit 2000-2006, Duratorq DI 2.4 (90PS), Diamond White 73
VIN Number: WF0LXXTTFL6Y07071
Registration Number: YS06MOU (14.07.2006)
First Registration Date: 14.07.2006
Primary Features
Build Date: 12.02.2006
Vehicle Line: Transit 2000-2006
Engine: Duratorq DI 2.4 (90PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-G-C)
Minor Features
With High Roof
LH Sliding Side Cargo Door - High
Marketing Level 3
With Complete Rear Hardboard Trim
With Front Roof Grab Handle
With Cargo Stowage Rail (Mid)
With Rear Step - Centre
Passenger Lrg Head/Short Arm Mirror
Fleet Key
With Driver Air Bag
Any Brand Tyre Vendor
With Improved Attitude/Ride Height
With Manual Clutch
With Recirculating Heater
With Radio Pre-Equipment Pack 1
4000 Series
With Power Point Plug
With Load Compartment Lamp
Less High Mounted Stop Lamp
Chug
Postby Chug » Wed Sep 22, 2021 8:04 pm
stevedunkgrass wrote:Hi
BF14ECV
We are sorry, but no information could be found for the Registration number you entered - BF14ECV
Chug
Postby tbullivant » Wed Sep 22, 2021 8:46 pm
Thanks Chug! Much appreciated :)
tbullivant
