DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby Chug » Fri Apr 15, 2022 10:20 am
legolamb wrote:Hi,
Could someone help me out with the following?
Transit VIN: WF0XXXBDFXCD42942
Thanks in advance
Transit 2006-2014, 2.2L CR TC I4 DSL 125 PS, Blazer Blue
VIN Number: WF0XXXBDFXCD42942
Registration Number: MV62OHW (01.10.2012)
First Registration Date: 01.10.2012
Registration Country: GB
Primary Features
Build Date: 10.07.2012
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 300S Series
Engine: 2.2L CR TC I4 DSL 125 PS
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.36/3.05
Emission: Stage V LDT3 Emissions
Air Conditioning: Manual Air Conditioning
Territory: (+)"GB"
Paint: Blazer Blue
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With Low Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Narrow Door Width
Low Door Height
With Kerbside Side Load Doors
With Diesel Particulate Filter
Less Back Panel Bulkhead Grille
With Full Partition
With Hinged Rear Loading Doors
With 180° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Rear Door Catch
Less Liftgate
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Southampton Plant Built
Less Special Equipment Package
Less Marketing Flex Prep Pack
Less Sales Badge
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
Less Visibility Package
Less Dress Up RSO
Less Paint Package
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
With Rear Blanking Panel
Less Rear Side/Back Security Glass
With Heated Windscreen
Less Heated Rear Window
Less Overhead Console
Less Header Mounted Package Tray
Less Rear Compartment Trim Panel
Less Inter Cladding Surfaces
Less Front Floor Mats
Flr Cvr-Rubber Ins-Extended
With Bright Air Vent Knob
With Partial Headlining - Moulded
With Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
With Load Space Tie Down Loop
Less Load Floor Covering
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Running Boards
Less Roof Rack
Less Exterior Body Mouldings
Less Rear Window Protector
Less Rear Step
Less Rear View Mirror
Large Head/Short Arm Mirror
Manual Dual Mirror-Manual Fold Back
Less Seat Construction
Less Rear Underseat Stowage Bin
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Rear Seat Recliner
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Less Rear Seats Fixings
Less 2nd Row Reversed Triple Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Removable 2nd Row Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Less Fleet Key
With Door Auto Relocking - Enabled
Less Zonal Opposite Door Relocking
Less Configurable Unlocking
With Door Dead Locks
With Power Lock Group
Two Step Door Unlock System
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rain Sensor - Front W/Wiper
Less Sun Roof
Less Rear Sunroof
Self Colour Rear Bumper End Caps
Mid Grey Front Bumper
Rear Plastic Grey Bumper-With Step
Less Rear Bumper Under Run
Less Bumper Underrun - Front
Less Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
With Spare Tyre Security Package
With Single Rear Wheels
5 1/2J x 15 Steel Wheel
195/70R 15C LI 104/102 BSW
With Wheel Hub Cap
Non Locking Lug Nuts
Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
Dual Mass Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
Less Rear Stabilizer Bar
With Down Turned Exhaust Exit
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
Less Skid Plates
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Basic Type Steering Wheel
Less Auxiliary Heater
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
Less Tachograph
Less Tripminder Assy
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
With Reverse Proximity Sensor
Less Anti-Theft Alarm
Less Engine Immobiliser
Standard Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
Less Radio Pre-Equipment Pack
Less Bluetooth
Roof Mounted Radio Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 5
Less Telephone
Less Telephone Preparation Pack
Less Microphone
Less Voice Activated Modules
With Column Stalk Radio Controls
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
With Daytime Running Lamps
Less Front Fog Lamps
Less Roof Marker/Clearance Light
Less Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
Less Side Marker Lamps
With High Mounted Stop Lamp
Less Roof Mounted Turn Signals
Less Rear Marker Lamps
With Front Headlamp Levelling
Less Headlamp Control
Less Instrument Panel Dimmer Switch
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
Chug
Postby legolamb » Sat Apr 16, 2022 8:27 pm
Thank you for the info it's much appreciated.
legolamb
Postby Virgil4747 » Tue Apr 19, 2022 12:11 pm
Pretty please ... WF0LXXGBFL3L58572 ... TY!
Virgil4747
Postby Chug » Tue Apr 19, 2022 11:16 pm
Virgil4747 wrote:Pretty please ... WF0LXXGBFL3L58572 ... TY!
Transit 2000-2006, 2.4L Duratorq DI (120/125PS), Colorado Red
VIN Number: WF0LXXGBFL3L58572
Registration Number: LT53FEH (05.09.2003)
First Registration Date: 05.09.2003
Primary Features
Build Date: 06.05.2003
Vehicle Line: Transit 2000-2006
Series: 1.7-350L Series
Engine: 2.4L Duratorq DI (120/125PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Colorado Red
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-I-C)
Chug
Postby Virgil4747 » Wed Apr 20, 2022 1:43 pm
TY muchly!!
Virgil4747
Postby 1234Tranny » Mon May 02, 2022 4:12 pm
Hi,
Could someone help me out with the following for my new van?
Transit Custom Reg MT21ZND
Thanks in advance
1234Tranny
Postby Welshhobo » Tue May 17, 2022 10:43 pm
Could you do mine please?
FE57 CZA
Welshhobo
Postby jonochap » Sat May 28, 2022 10:10 am
Hello mk6 and 7 people, as you may be aware this is a new part of ftf to me and still looking for information for stepdaughter #1 dogo groom…can I please have any etis information on EK56 OCV? Thank you ever so
Owner of not so troubled puk :)
jonochap
Postby Fullsendvanner » Sun May 29, 2022 11:58 am
Hi having a few problems trying to get a build sheet for my transit
If anyone could help me out it would be much much much appreciated.
Wf0XXXTTGXFP44089
Thankx
Fullsendvanner
Postby Chug » Sun May 29, 2022 11:20 pm
1234Tranny wrote:Hi,
Thanks in advance
Transit/Tourneo Custom 2012, 2.0 EcoBlue F, Orange Glow
VIN Number: WF0YXXTTGYMM41452
Registration Number: MT21ZND (18.05.2021)
First Registration Date: 18.05.2021
Primary Features
Build Date: 18.03.2021
Vehicle Line: Transit/Tourneo Custom 2012
Series: 300L Series
Engine: 2.0 EcoBlue F
Drive: RHD FWD
Axle Ratio: 4.429/3.263 Final Drive Ratio
Emission: Stage 6.2 Emissions
Territory: (+)"GB"
Paint: Orange Glow
Interior Fabric: Inroad/Marl Ebony
Minor Features
Less Underbody Protection
With Low Roof
With Rear Mudflaps
Less Cargo Stowage Device
Mini Media Hub (2XUSB) Adp BSL+BT
With Front Mudflaps
Bulkhead With Load Through Hatch
Less Liftgate
Less Tie Down Hooks
Otosan (Turkey) Plant Build
Less Security Lock Group
Complete Vehicle
Calculat GVW Or Pick Frm Table
Less Special Order Paint
Less Diagnostic Maintenance Monitor
Marketing Level 5
With Visibility Pack High
Less Dress Up RSO
Exterior Paint - Solid
Less SVO Except Packs
Less VP Application Label
With Tool Kit
Power Frt Window-1 Tch Dwn-Dr Only
With Tinted Glass All Round
Less Rear Window
Less Console Ashtray
With Locking Glove Box Lid
With Mini Overhead Console
Int Enviro Colour-Dark Palazzo Grey
Interior Feature Colour - Ebony
With Complete Rear Hardboard Trim
Interior Trim Accent Pack C
Floor Cover - Rubber Ins-Partial
Less Sun Blinds
With Illuminated Sunvisor - Drivers
With Illuminated Sunvisor-Passenger
Less Rear Coat Hook
Less Rr Interior Overhead Stowage
Less Luggage Compartment Net Kit
8 Load Compartment Tie Down Loops
Load Floor Liner-Molded
Less First Aid Retain Straps
Load Area Protection Kit 2
Interior Grab Handles - 1
Less Noise Insulation Package
Roof Storage-Driver Sunglasses
Less Running Boards
With Colour Keyed Exterior Pack
Grille-Mid 3 Bar With MIC/Chrmd Bar
Less Roof Rack
Wide Bodyside Mldg - Body Colour
Less Spoiler
Less Rear Step
Dual Ext Pwr Mirror-Power Fold Back
With Body Coloured Exterior Mirror
Less Auto Dipping Mirror System
With Drivers Seat Armrest
With Front 2 Way Headrest
Tray/Table - Front Seat
Less Rear Headrest
Less Rear Seat Centre Armrest
With Drivers Manual Lumbar Support
Less Passenger Seat Lumbar Support
With Drivers Heated Seat
With Heated Passenger Seat
St Belt Minder-Drvr/EU Tel&Snd
Drivers 4-Way Man With Cushion Tilt
With Pass 2 Way Manual Seat Adjust
Less Trailer Sway Control (TSC)
Less Device Dock
Less Tablet Holder
Less Fuel Economy Pack
Body Coloured Exterior Door Handle
Body Coloured Tailgate Handle
With Leather Gear Shift Knob
Less Fleet Key
Configurable Unlocking - Conf 1
Power Door Deadlocks - Shielded
Remote Control Door Entry - 2 Fob
With Automatic Windscreen Wiper
Washer Tank Level Warning Lamp
Less Body Tu-Tone Paint
Less U/Body Corrosion Protect
Less Bodyside Accent Stripe
Less Hood Accent Stripe
Front Bumper Body Coloured Plastic
Rear Bumper-Painted Body Colour
Less Restraint Devices
Less Air Curtain Restraint
Less Air Curtain Restraint RH
With Inertia Front Seat Belt
With Driver Air Bag
With Passenger Air Bag
Seat Belt - Black
With Passenger Air Bag Deactivation
Less Isofix Hard Point Attach
Seat Belt Pretensioners Drv/Pass
Less Drv/Pass Seat Mounted SD A/Bag
Less Tyre Pressure Sensors
6.5 x 16" Alloy - Style A
Less Wheel Covers
Locking Wheel Nuts
Less MPH Engine Governor
Starter - Stop/Start System
Stage 6.2 Emissions
With Standard Suspension
Less Brake Dust Shields
Non - Limited Slip Front Axle
With Mechanical Parking Brake
Less Collision Mitigation System
With Anti Lock Brakes And ESP+
Less Premium Brakes
With Pollen Filter
Less Ventilation System
With Recirculating Heater
A/C Refrigerant-R134A
Less Auxiliary Fuel Ports
With Single Fuel Tank
Non Locking Capless Fuel Fill
Fuel Tank Fill Neck-With Inhibiter
With Manual Tilt/Slide Stg Column
Leather Steering Wheel
Less Electronic Speed Limitation
With Speed Control
Less Spd Control Distance Sensing
With Low Series Cluster
Less Tachograph
With Trip Computer
Dual Note Electric Horn
MFD TFT Touch Screen
Less Navigation System
Emergency Assistance
Less Revers Gear Alarm
Less Lane Departure Warning System
Less Driver Impairment Monitor
Less Mass Movement Sensor
Less Blind Spot Information System
Less Lane Keeping Aid
Less Speed Sign Recognition
Thatcham Catergory 1 Alarm System
With Vehicle Tilt Sensing
With Rear Parking Aid
With Front Parking Aid
Less Side Parking Aid
Less Automated Parking System
Extra Heavy Duty Alternator
Less A/V Jack
ICE-Low W/Incr Connectivity + DAB
ICE Feature Pack 21
ICP - Mini Electronic Finish Panel
Radio Speakers-2 Woofers/2 Tweeters
Less Mobile Office Pack
Less Multi Media/Telematics System
Less Cell Phone Interface System
Microphone
Less Sync
With Steering Wheel Radio Controls
Electrical Outlet
Less Camera
Less Safe Deposit Box
With Auto Headlamps
Halogen Projector Headlamps
Daytime Running Lamps Level 2
With Quad Beam Headlamps
Front Fog Lamps-Adaptive Corner
Rear Door Edge Warn Reflectors
Less Interior Light Group
With Footwell Lights
Header Mounted Courtesy/Maplights
Less Courtesy Light Delay
Less Rear Overhead Reading Lamps
Load Compartment Light - LED
With Automatic Headlamp Control
Less Programble Interface Module
Less Battery Cut Off Relay
Less Wiring Harness
Less Fleet
Chug
Postby Chug » Sun May 29, 2022 11:21 pm
Welshhobo wrote:Could you do mine please?
FE57 CZA
Transit 2006-2014, 2.2L Duratorq-TDCi (110PS) - Puma, Colorado Red
VIN Number: WF0XXXTTFX7S16361
Registration Number: FE57CZA (19.09.2007)
First Registration Date: 19.09.2007
Primary Features
Build Date: 23.07.2007
Series: 280M Series
Engine: 2.2L Duratorq-TDCi (110PS) - Puma
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Colorado Red
Minor Features
With Low Roof
Low Door Height
With Dual Side Load Doors
With Full Partition - Steel
With SVO Low Roof Tailgate
Less Cargo Door Check Arms
With Cold Climate Liftgate
Marketing Flex Prep Pack 3
With Power Equipment Group
Marketing Level 3
Seat Pack 22
Rain Sensor - Fr Windscreen Wiper
With Standard Tread - Any Vendor
Ice Feature Pack 3
Less Dual Rear Wheel Pack
With Front Fog Lamps
With Automatic Headlamp On/Off
With Instrument Panel Dimmer Switch
Chug
Postby Chug » Sun May 29, 2022 11:23 pm
jonochap wrote:Hello mk6 and 7 people, as you may be aware this is a new part of ftf to me and still looking for information for stepdaughter #1 dogo groom…can I please have any etis information on EK56 OCV? Thank you ever so
Transit 2006-2014, Duratorq TDCI 2.4 (100PS), Frozen White
VIN Number: WF0XXXTTFX6B53900
Registration Number: EK56OCV (28.02.2007)
First Registration Date: 28.02.2007
Primary Features
Build Date: 02.09.2006
Engine: Duratorq TDCI 2.4 (100PS)
Drive: RHD RWD
Axle Ratio: 5.11
Territory: (+)"GB"
Paint: Frozen White
Minor Features
With High Roof
High Door Height
Full Partition/Fixed Glass Window
With 256° Cargo Door Check Arms
Complete Vehicle
Less Trim Pack
Marketing Level 3
European Environmental Label
With Black Air Vent Knob
With Front Roof Grab Handle
With Rear Step - Centre
Seat Pack 23
With Driver 8 Way Mnl.Seat Adjuster
With Front Towing Hook
Fleet Key
Less Float Mounting
Less Diesel Fuel Cooler
Front Axle Rating-Maximum
With Brake Only Traction Control
Less Transfer Case
Less A/C Unit - Roof Mounted
Fuel Water Separator Less Sensor
With Perimeter Anti-Theft
Drivers Seat Rechargeable Battery
Ice Feature Pack 3
With Smokers Package
With Auxiliary 6 Fuse Box
Chug
Postby Fullsendvanner » Mon May 30, 2022 4:51 pm
Pretty pretty please could you find out the info of this van off etis, I've tried always I can see my self but no luck
Thank you VERY much !!!
WF0XXXTTGXFP44089
Fullsendvanner
Postby 1234Tranny » Tue May 31, 2022 6:19 am
Thanks in advance
Primary Features
Series: 300L Series
Drive: RHD FWD
Territory: (+)"GB"
Paint: Orange Glow
Minor Features
With Low Roof
With Rear Mudflaps
With Front Mudflaps
Less Liftgate
Less Tie Down Hooks
Complete Vehicle
Marketing Level 5
Less Dress Up RSO
With Tool Kit
Less Rear Window
Less Sun Blinds
Less Rear Coat Hook
Less Running Boards
Less Roof Rack
Less Spoiler
Less Rear Step
Less Rear Headrest
Less Device Dock
Less Tablet Holder
Less Fleet Key
With Driver Air Bag
Seat Belt - Black
Less Wheel Covers
Locking Wheel Nuts
Stage 6.2 Emissions
Less Premium Brakes
With Pollen Filter
With Speed Control
Less Tachograph
With Trip Computer
Less A/V Jack
ICE Feature Pack 21
Microphone
Less Sync
Electrical Outlet
Less Camera
With Auto Headlamps
Less Wiring Harness
Less Fleet
1234Tranny
Postby The combat wombat » Sat Jun 04, 2022 5:37 pm
Please can you give me any info on this one?
WL06 FZE
The combat wombat
