doddy wrote:hi can someone check EK16 TFO WF0YXXTTGYFP40873 thank you trying to see if it has tow bar electric plug
Transit/Tourneo Custom 2012, 2.2L CR TC I4 DSL 100PS, Frozen White
VIN Number: WF0YXXTTGYFP40873
Registration Number: EK16TFO (31.03.2016)
First Registration Date: 31.03.2016
Registration Country: GB
Primary Features
Build Date: 14.12.2015
Vehicle Line: Transit/Tourneo Custom 2012
Cab Style: Regular Cargo Van
Series: 270S Series
Engine: 2.2L CR TC I4 DSL 100PS
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.188/3.045 Final Drive Ratio
Emission: Stage V LDT3 Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Fabric: Traxon/Max Charcoal Black
Minor Features
Less Underbody Protection
With Low Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Accessory USB Unit
With Front Mudflaps
With Kerbside Side Load Doors
With Diesel Particulate Filter
Less Back Panel Bulkhead Grille
Bulkhead With Load Through Hatch
With Hinged Rear Loading Doors
With 180° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Liftgate
Less Auxiliary I/P Console
With Standard GVM Rating
Otosan (Turkey) Plant Build
Less Special Equipment Package
Complete Vehicle
Less Marketing Flex Prep Pack
Less Sales Badge
Less Special Order Paint
Less SVO Application/Label
Less Special Value Packages
Marketing Level 3
Less Visibility Package
Less Dress Up RSO
Exterior Paint - Solid
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
Power Front Windows One Touch Up/Do
With Tinted Glass All Round
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
Less Rear Window
Less Heated Windscreen
Less Heated Rear Window
Less Console Ashtray
With Glove Box Lid
Less Overhead Console
Interior Environment Colour-Pewter
Int Feat Colour - Charcoal Black
Less Header Mounted Package Tray
Less Rear Compartment Trim Panel
Interior Trim Accent Pack A
Floor Cover - Rubber Ins-Partial
Less Sun Blinds
With Partial Headlining - Moulded
Non Illuminated Sunvisor - Drivers
Non Illuminated Sunvisor-Passenger
Less Rear Coat Hook
Less 'B' Pillar Assist Handle
Less Rr Interior Overhead Stowage
8 Load Compartment Tie Down Loops
Less Load Floor Covering
Less First Aid Retain Straps
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Less Interior Grab Handles
Less Interior Partition
Less Driver Roof Storage
Less Running Boards
Less Exterior Chrome Pack
Less Roof Rack
Wide Bodyside Moulding-Grey
Less Rear Window Protector
Less Side Auxiliary Step
Less Rear View Mirror
Dual Manual Signal Mirror-Black
With Black Exterior Mirror
Less Auto Dipping Mirror System
Seat Pack 4
Less Under Seat Stowage Facility
With Drivers Seat Armrest
Less Passenger Seat Armrests
With Front 2 Way Headrest
Less Tray/Table - Front Seat
Less Rear Headrest
Less Rear Seat Centre Armrest
Less Rear Seat Recliner
Less Driver Seat Lumbar Support
Less Passenger Seat Lumbar Support
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
St Belt Minder-Drvr/EU Tel&Snd
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Drivers 4-Way Man With Cushion Tilt
With Pass 2 Way Manual Seat Adjust
Less Rear Seat Packs
Less Trailer Towing Attachments
Less Trailer Sway Control (TSC)
Less Fuel Economy Pack
Exterior Door Handle - Black
Lift/Bootlid Handle Exterior-Black
With Moulded Gearshift Knob
Less Fleet Key
With Door Auto Relocking - Enabled
Less Zonal Opposite Door Relocking
Configurable Unlocking - Conf 1
Power Door Deadlocks - Shielded
Two Step Door Unlock System
Door Entry Remote-Multi Channel
Less Keyless Entry System
Less Rear Window Wiper/Washer
With Variable Intermittent Windscreen Wiper
Less Heated Washer Jet
Less Headlamp Washer/Wiper
Less Washer Tank Level Warning Lamp
Less Sun Roof
Less U/Body Corrosion Protect
Less Bodyside Accent Stripe
Less Front Bumper Sensor Device
Front Bumper - Partial Body Colour
Rear Bumper - Self Colour
Less Air Curtain Restraint
Less Air Curtain Restraint RH
With Inertia Front Seat Belt
Less Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
With Passenger Air Bag Deactivation
Less Isofix Hard Point Attach
Seat Belt Pretensioners Drv/Pass
Less Drv/Pass Seat Mounted SD A/Bag
Tyre Carrier Drop-Dr Open
With Steel Spare Wheel
Less Tyre Pressure Sensors
Less Spare Tyre Lock
6 1/2J x 15 Steel Wheel
With Wheel Hub Cap
Non Locking Lug Nuts
Less MPH Engine Governor
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
With Standard Suspension
Less Brake Dust Shields
With Mechanical Parking Brake
Less Collision Mitigation System
Brakes-ESP/HLA/FBS
Less Premium Brakes
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
Less Pollen Filter
With Recirculating Heater
Less Auxiliary Fuel Ports
With 80 Litre Fuel Tank
Non Locking Capless Fuel Fill
With Diesel Fuel Capability
Fuel Tank Fill Neck-With Inhibiter
With Manual Tilt/Slide Stg Column
Basic Type Steering Wheel
Less Electronic Speed Limitation
Less Speed Control
Less Auxiliary Heater
Less Rear Compartment Heating
Low Series Analog Cluster
Less Instrument Cluster - Rheostat
With MPH/KMH Speedometer
Less Tachograph
Less Tripminder Assy
Dual Note Electric Horn
Less Multi Function Display
Less Navigation System
Less Navigation Data
Less Emergency Assistance
Less Revers Gear Alarm
Less Lane Departure Warning System
Less Driver Impairment Monitor
Less Blind Spot Information System
Less Speed Sign Recognition
Less Anti-Theft Alarm
Less Vehicle Tilt Sensing
Less Rear Parking Aid
Less Front Parking Aid
Standard Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
With A/V Jack
Less Bluetooth
Roof Mounted Radio Antenna
ICE- Mid Audio (1C) W/Connectivity
Ice Feature Pack 2
Less Integrated Control Panel
Radio Speakers-2 Woofers/2 Tweeters
Microphone
Less Sync
Less Voice Activated Modules
With Steering Wheel Radio Controls
Less Column Stalk Radio Controls
Less Steering Wheel MFD Controls
Electrical Outlet
Less Power Point Plug
Less Power Point Plug - Rear
Less Camera
Less Safe Deposit Box
With Auto Headlamps
With Halogen Headlamp
With Daytime Running Lamps
With Quad Beam Headlamps
Less Front Fog Lamps
Rear Door Edge Warn Reflectors
Less Cornering Lamp
Less Footwell Lights
With Header Courtesy Light
Less Rear Overhead Reading Lamps
Less Glove Box Illumination
With Load Compartment Lamp
With High Mounted Stop Lamp
Less Roof Mounted Turn Signals
With Front Headlamp Levelling
Less Headlamp Control
Less Programble Interface Module
Less Battery Cut Off Relay
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
