Jumbo123 wrote:hi could someone give me the info for my van please ? reg is WJ61VTL
thanks!!
Transit 2006-2014, 2.4L Duratorq (85kW/115PS), Frozen White
VIN Number: WF0XXXTTFXBY60627
Registration Number: WJ61VTL (26.09.2011)
First Registration Date: 26.09.2011
Registration Country: GB
Primary Features
Build Date: 09.06.2011
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 350E Series
Engine: 2.4L Duratorq (85kW/115PS)
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.73
Emission: Stage IV Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With High Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Wide Door Width
High Door Height
With Kerbside Side Load Doors
Less Diesel Particulate Filter
Less Brake System-Regenerative
With Full Partition - Steel
With Hinged Rear Loading Doors
With 256° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
With Magnetic Rear Door Catch
Less Liftgate
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Otosan (Turkey) Plant Build
Less Special Equipment Package
Less Marketing Flex Prep Pack
Less Sales Badge
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
Less Visibility Package
Less Dress Up RSO
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
With Rear Blanking Panel
Less Rear Side/Back Security Glass
Less Heated Windscreen
Less Heated Rear Window
Less Overhead Console
With Header Mounted Package Tray
Less Rear Compartment Trim Panel
Less Inter Cladding Surfaces
Less Front Floor Mats
Flr Cvr-Rubber Ins-Extended
With Bright Air Vent Knob
With Partial Headlining - Moulded
With Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
With Load Space Tie Down Loop
Less Load Floor Covering
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 1
Less Running Boards
Less Roof Rack
Less Exterior Body Mouldings
Less Rear Window Protector
With Rear Step - Centre
Less Rear View Mirror
Large Head/Short Arm Mirror
Manual Dual Mirror-Manual Fold Back
Less Seat Construction
Less Rear Underseat Stowage Bin
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Rear Seat Recliner
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Less Rear Seats Fixings
Less 2nd Row Reversed Triple Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Removable 2nd Row Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Less Fleet Key
With Door Auto Relocking - Enabled
Less Configurable Unlocking
With Door Dead Locks
With Power Lock Group
Two Step Door Unlock System
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rain Sensor - Front W/Wiper
Less Sun Roof
Less Rear Sunroof
Less Rear Bumper Under Run
Less Bumper Underrun - Front
Less Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
With Spare Tyre Security Package
With Single Rear Wheels
5.5 X 16" Steel Wheel
215/75R 16C 116/114
Non Locking Lug Nuts
Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
Dual Mass Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
Less Rear Stabilizer Bar
With Down Turned Exhaust Exit
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
Less Skid Plates
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Basic Type Steering Wheel
Less Auxiliary Heater
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
Less Tripminder Assy
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
Less Reverse Proximity Sensor
Less Anti-Theft Alarm
Less Engine Immobiliser
Extra Heavy Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
Less Radio Pre-Equipment Pack
Less Bluetooth
Roof Mounted Radio Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 5
Less Telephone
Less Telephone Preparation Pack
Less Microphone
Less Voice Activated Modules
With Column Stalk Radio Controls
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
Less Daytime Running Lamps
Less Roof Marker/Clearance Light
Less Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
With Side Marker Lamps
With High Mounted Stop Lamp
Less Roof Mounted Turn Signals
Less Rear Marker Lamps
With Front Headlamp Levelling
Less Headlamp Control
Less Instrument Panel Dimmer Switch
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
