4L1 wrote:Hi guys could someone please provide info on RJ16XPM
Also how can you tell if a van has heated seats?
TIA
Transit 2014-, 2.2L CR TC I4 DSL 155PS, Shadow Black (Mica)
VIN Number: WF0XXXTTGXGG58512
Registration Number: RJ16XPM (10.06.2016)
First Registration Date: 10.06.2016
Registration Country: GB
Primary Features
Build Date: 28.04.2016
Vehicle Line: Transit 2014-
Cab Style: Regular Cargo Van
Series: 350M Series
Engine: 2.2L CR TC I4 DSL 155PS
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.714/3.30 Final Drive Ratio
Emission: Stage V LDT3 Emissions
Air Conditioning: Manual Air Conditioning
Territory: (+)"GB"
Paint: Shadow Black (Mica)
Interior Fabric: Lane/Max Charcoal Black
Minor Features
Less Underbody Protection
With High Roof
Less Roof Line Conversion
With Rear Mudflaps
Accessory Media Hub 1XUSB
Less Front Mudflaps
With Kerbside Side Load Doors
With Diesel Particulate Filter
With Hill Launch Assist
Less Back Panel Bulkhead Grille
With Full Partition - Steel
Rear Cargo Door-Hinged 250DEG
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Otosan (Turkey) Plant Build
Less Special Equipment Package
Complete Vehicle
Less Marketing Flex Prep Pack
Less Sales Badge
Less Special Order Paint
With SVO Application/Label
Less Special Value Packages
Less Power Equipment Group
Marketing Level 4
With Visibility Pack High
Exterior Paint - Solid
Less Cooling Pack
Less VP Application Label
Less Certification Label
Less SVO Marketing Packs
Less Fire Extinguisher Fixings
Less Tool Kit
Kit - Tyre Repair Service
Power Front Windows One Touch Up/Do
With Tinted Glass All Round
Less 2nd Row RH Side Window
Less 2nd Row LH Side Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
Less 4th Row RH Side Window
Less 4th Row LH Side Window
Less Rear Window
With Heated Windscreen
Less Heated Rear Window
Less Console Ashtray
With Locking Glove Box Lid
With Standard Overhead Console
Interior Environment Colour-Pewter
Int Feat Colour - Charcoal Black
With Header Mounted Package Tray
Side/Rear Door Trim Panel-Level 1
Interior Trim Accent Pack B
Floor Cover - Rubber Ins-Partial
With Partial Headlining - Moulded
Sunvisor Less Mirror - Drivers
Sunvisor Less Mirror - Passenger
Less Rear Coat Hook
Less A Pillar Assist Handle
With B Pillar Assist Handle
With Load Space Tie Down Loop
Load Floor Liner-Molded
Less First Aid Retain Straps
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Less Interior Grab Handles
Less Interior Partition
Roof Storage-Driver Sunglasses
With Grey Grille
Wide Bodyside Moulding-Grey
Less Rear Window Protector
Less Side Auxiliary Step
Less Rear View Mirror
Large Head/Short Arm Mirror
Dual Ext Pwr Mirror-Power Fold Back
Less Auto Dipping Mirror System
Seat Pack 13
With Drivers Seat Armrest
Less Passenger Seat Armrests
With Front 2 Way Headrest
Tray/Table - Front Seat
Less Rear Headrest
Less Rear Seat Centre Armrest
Less Rear Seat Recliner
With Drivers Manual Lumbar Support
Less Passenger Seat Lumbar Support
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
St Belt Minder-Drvr/EU Tel&Snd
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Less 2nd Row Reversed Triple Seat
Drivers 4-Way Man With Cushion Tilt
With Pass 2 Way Manual Seat Adjust
Less Rear Seat Packs
Less Trailer Towing Attachments
Rear Axle Alternative A
Less Trailer Sway Control (TSC)
Less Fuel Economy Pack
Exterior Door Handle - Black
Lift/Bootlid Handle Exterior-Black
With Leather Gear Shift Knob
Less Fleet Key
With Door Auto Relocking - Enabled
Less Zonal Opposite Door Relocking
Configurable Unlocking - Conf 1
Power Door Deadlocks - Shielded
Two Step Door Unlock System
Remote Control Door Entry - 2 Fob
Less Keyless Entry System
Less Rear Window Wiper/Washer
With Automatic Windscreen Wiper
Less Headlamp Washer/Wiper
Washer Tank Level Warning Lamp
Less Rear Sunroof
Less U/Body Corrosion Protect
Less Bodyside Accent Stripe
Front Bumper - Partial Body Colour
Rear Bumper - Plastic Unpainted
Less Rear Bumper Under Run
Less Front License Plate Bracket
Less Bumper Underrun - Front
Less Air Curtain Restraint
Less Air Curtain Restraint RH
Less Beltminder
With Inertia Front Seat Belt
Less Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
Less Passenger Air Bag Deactivation
Less Isofix Hard Point Attach
Seat Belt Pretensioner - Drivers
Less Drv/Pass Seat Mounted SD A/Bag
Less Tyre Carrier Opener
Less Side Underrun Rails
Less Spare Wheel
Less Tyre Pressure Sensors
Less Spare Tyre Lock
With Single Rear Wheels
6.5 X 16" Steel Road Wheel
With Full Wheel Cover
Non Locking Lug Nuts
Less MPH Engine Governor
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
Front Axle Rating-Normal
Less Brake Dust Shields
With Down Turned Exhaust Exit
With Mechanical Parking Brake
Less Collision Mitigation System
Less Brake Emergency Assist
Brakes-ESP/HLA/FBS
Less Tracking System - FIA
Less Transfer Case
With Sngle.L/B Dvr/Dual L/B Pass.St
Less Rear Seat Climate Control
With Pollen Filter
With Recirculating Heater
A/C Refrigerant-R134A
Less Auxiliary Fuel Ports
With 80 Litre Fuel Tank
Non Locking Capless Fuel Fill
With Diesel Fuel Capability
Fuel Tank Fill Neck-With Inhibiter
With Manual Tilt/Slide Stg Column
Leather Steering Wheel
Electronic Speed Limiting Device
With Speed Control
Less Auxiliary Heater
Less Rear Compartment Heating
With Conventional Instrumentation
With Instrument Cluster - Rheostat
With MPH/KMH Speedometer
Less Tachograph
With Trip Computer
Dual Note Electric Horn
MFD Nav Low TFT Screen
Less Navigation System
Less Navigation Data
Less Emergency Assistance
Less Revers Gear Alarm
Less Lane Departure Warning System
Less Driver Impairment Monitor
Less Speed Sign Recognition
Thatcham Catergory 1 Alarm System
With Vehicle Tilt Sensing
With Rear Parking Aid
With Front Parking Aid
Standard Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
With A/V Jack
Roof Mounted Radio Antenna
ICE-Low Audio (0C) With DAB
ICP Nav
Radio Speakers-2 Woofers/2 Tweeters
Microphone
With Media Gateway Module
Less Voice Activated Modules
With Steering Wheel Radio Controls
Less Steering Wheel MFD Controls
Electrical Outlet
Less Power Point Plug
Less Power Point Plug - Rear
Rear View Camera-Fixed
Less Safe Deposit Box
Less Dual Rear Wheel Pack
With Auto Headlamps
With Halogen Headlamp
With Daytime Running Lamps
Headlamps-Static Bending
With Front Fog Lamps
Less Roof Marker/Clearance Light
Rear Door Edge Warn Reflectors
Less Cornering Lamp
With Footwell Lights
Header Mounted Courtesy/Maplights
Less Rear Overhead Reading Lamps
Less Glove Box Illumination
Load Compartment Light - LED
Less Side Marker Lamps
With High Mounted Stop Lamp
Less Roof Mounted Turn Signals
With Rear Fog Lamps
Less Rear Marker Lamps
With Front Headlamp Levelling
With Automatic Headlamp Control
Less Programble Interface Module
Less Battery Cut Off Relay
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
