fuel pump
fuel pump
Postby the.little.fatboy » Sat Jan 17, 2009 2:18 pm
hi i have a 2002 52reg fwd 75psi t280 transit van i have taken the fuel pump off and put it back on agian can some1 tell me how to self bleed it off the key all help welcome thanx jim :x
if it brakes fix it if you cant fix it scrap it and buy a ford transit
also collecting scrap metal in northampton and milton keynes area's
the.little.fatboy
Re: fuel pump
Postby Frag » Sat Jan 17, 2009 2:37 pm
If your filter head has an hand primer fitted,leave injector pipes loose at injectors,pump primer with ignition turned on & it will start to run out of inj. pipes.
Crank engine & continue to pump hand primer till fuel spraying out of injector pipes with no air/bubbles then tighten them up should fire up.
If no hand primer do same as above but just fill filter with fuel first,then crank till fuel at injectors then tighten pipes.
A good/fully charged battery is a big help. :)
Frag
Ford Technician
Re: fuel pump
Postby sootymax » Sat Jan 17, 2009 10:45 pm
can i ask where you got the pump timing tool from and how much
sootymax
Re: fuel pump
Postby winterheating » Sat Jan 17, 2009 10:56 pm
Frag wrote:If your filter head has an hand primer fitted,leave injector pipes loose at injectors,pump primer with ignition turned on & it will start to run out of inj. pipes.
does this apply to tdci, is it the solonoids on pump that open with ignition on?
winterheating
