i don't mind dropping to forth gear occasionally but don't want to be spanking the clutch and chasing the gears all the time!!!
winterheating wrote:i would of thought with your power increase allready it will help a lot.
as youve allready got more power to weight than standard it shouldn't kill your acceleration.
i've just bought a 6 speed mondeo box for my van![]()
i can't wait to see the difference, and if it kills my accceleration, i'll just have to get the power up to match.
jolly olly wrote:Can anyone post up the the details of a mk 6 90 ps (lwb semi if it makes any difference) cheers.
lostpaul67 wrote:This will tell you about the gearing
FORD TRANSIT 115PS 2.4L Duratorq TDdI
TECHNICAL SPECIFICATIONS
Engine type 2.4 litre TDdi DuraTorq North / South Installed
Displacement – cc 2402
Fuel type Diesel (max. 5% RME content)
Bore mm 89.9
Stroke mm 94.6
Max power kW/PS at rpm 84.6/115 @ 3800
Torque ISO Nm at rpm 285 @ 2300
Construction
Cylinders 4
Cylinder head Aluminium
Cylinder block Cast Iron
Compression 18.5:1 (+/- 0.5)
Valve gear 4 valves per cyl / twin cam with hydraulic adjust
Camshaft drive Duplex chain
Engine management Visteon EEC
Fuel injection Bosch – Pump Line Nozzle VP44
Forced Induction system Mitsubishi FGT (Fixed Geometry Turbo)
Fuel Economy
(MPG)
Final Drive ratio ...4.63 .......5.13 ......5.88
Urban ...............25.4 ......24.6 ..... 20.8
Extra Urban .......42.8 ......37.7 .....35.8
Combined ..........34.0 ......31.7 .....28.2
GTM
(350 LWB Hi Roof) 5000KG 5750KG 6000KG
Transmission
Gear ratios
1 st ...... 4.20
2 nd .....2.24
3 rd .....1.37
4 th ..... 1.00
5 th ..... 0.76
Reverse 3.60
Final Drive 4.63, 5.13 or 5.88
Flywheel Dual Mass Flywheel
Clutch 258mm self-adjusting single driven-plate clutch with low pedal-operating load.
Performance
Final drive ratio ..................4.63 ......5.13 ......5.88
Maximum speed, kph/mph ...145/90 ... 139/86 ...125/78
0-100kph/62mph ..................26 ..........26 .........26
50-100kph/31-62mph .............22 ..........20 .........24
winterheating wrote:thats good info there Lostpaul,
the 0-62 times conclude that the first few gears are the same ratio, do you think
