T260 vs T280 FWD - what are the differences?
Postby Vee4 » Sat Mar 21, 2009 11:38 am
One difference is GBP500 on the list price.
The Ford specification says the Kerb Mass is the same (1699kg for 85/110PS) so no mass is added by heavier suspension components, reinforced chassis, heavy duty tyres, etc. The Gross Payload is 200kg higher, of course.
If the van is run lightly loaded most of the time, would a T280 have a longer life than a T260 because of uprated suspension components?
I'm hoping some of the Ford 'insiders' can elucidate.
'69 Mk1 V4 :) >> '76 Mk1 V4 :) >> '84 Mk2 OHC :wink: >> '97 Mk5 Banana :D >> '09 Mk7 TDCi 8)
The van in front is a Transit. It might be my Mk7 - follow the trail of rusty water: Diary of an Ordinary Van
Vee4
Re: T260 vs T280 FWD - what are the differences?
Postby pikeybob » Sat Mar 21, 2009 11:42 am
In therory yes. But if its gonna be run with a light payload they''ll last as long as each other :wink:
The only mk7 still with ORIGINAL egr valve!!!!!!
pikeybob
Postby ake » Sat Mar 21, 2009 12:10 pm
I'm pretty sure that the suspension components are all the same, if you are just goin to run lightly loaded then buy the 260 and save the £500
Postby Vee4 » Sat Mar 21, 2009 12:22 pm
ake wrote:I'm pretty sure that the suspension components are all the same, if you are just goin to run lightly loaded then buy the 260 and save the £500
It would be a lot to pay for a different badge on the back. Perhaps buy a T260 and then a T280 badge from the spares department - or is it the T280 badge that costs GBP500?
Vee4
Postby sc_BK » Sat Mar 21, 2009 12:53 pm
Are you sure there's a 200kg gross difference between the two?
sc_BK
Postby Dan T » Sat Mar 21, 2009 1:16 pm
It's not the door trim badge that lets you carry the weight, it's the VIN plate.
There is only 40kg difference in payload between the 260 and 280 if i remember correctly.
Dan T
Postby Vee4 » Sat Mar 21, 2009 1:18 pm
sc_BK wrote:Are you sure there's a 200kg gross difference between the two?
I think that is the point of the different nomenclature: T260 = 2600kg GVM, T280 = 2800kg GVM.
The specifications are here (although out of date, like many other things on the Ford website):
http://www.ford.co.uk/Commercialvehicle ... ddownloads
Vee4
Postby 100 T280 » Sat Mar 21, 2009 1:21 pm
They are on the mk6, no difference, the 280 had the option of heavier duty springs, same as the 300 FWD.
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby Dan T » Sat Mar 21, 2009 1:24 pm
Best thing to do is look at a 260 VIN and a 280 VIN.
My 280 has a GVM 2640kg, GTW 3500kg, Max front axle 1400kg, Max rear axle 1550kg.
Dan T
Postby Vee4 » Sat Mar 21, 2009 3:12 pm
That's interesting - you'd think that should be called a T260!
Vee4
Postby lostpaul67 » Sat Mar 21, 2009 6:56 pm
During the early days of the Mk6 there was an issue with the model numbers and the relation to the Gvm ie. T280 with a Gvm of 2640kg, there were complaints made and Ford agreed to align these figures so that on later vans the T280 actually had a Gvm of 2800kg. There was an article about this in one of the commercial vehicle magazines at the time but I can't remember which one, hope this helps :)
T260/130ps Glx
My Mk7 Ford Transit161k miles
lostpaul67
GLX Posse - Founder member
Postby Vee4 » Sun Mar 22, 2009 10:31 am
lostpaul67 wrote:During the early days of the Mk6 there was an issue with the model numbers and the relation to the Gvm ie. T280 with a Gvm of 2640kg, there were complaints made and Ford agreed to align these figures so that on later vans the T280 actually had a Gvm of 2800kg. There was an article about this in one of the commercial vehicle magazines at the time but I can't remember which one, hope this helps :)
Even more interesting! You would complain if you paid extra for what you thought was 2800kg GVM and it turned out to be only 2640kg, with a lower payload than expected. Assuming that Ford sorted out the anomalies as mentioned above, the basis of my question is: what do you get for the extra £500?
Vee4
Postby Dan T » Sun Mar 22, 2009 11:25 am
The Axle's will be rated higher on the 280
Dan T
Postby Vee4 » Sun Mar 22, 2009 1:45 pm
Thanks, Dan.
The spec says:
Front axle plated mass T260 = 1450kg T280 = 1450kg
Rear axle plated mass T260 = 1475kg T280 = 1650kg
So you get a slightly uprated rear axle and (presumably) slightly stiffer springs, allowing you to put another 175kg over the rear axle?
Vee4
