Hi all,
Anyone shed any light please on the following. We have an 02 reg Transit 350 tipper that developed a rattle on tickover. We stripped and replaced the dual mass flywheel and clutch. Upon reassembly it will start, then immediateley cut out again. Checked with fault code reader, which suggested the Crank Position Sensor. Replaced this, still the same. Stripped out the flywheel again! and confirmed that it is identical to the old unit. Rebuilt, and as before will start straight away, then cut out immediately. Immobilsor checks out fine. When it starts it runs for only a second or two. ????????????????????
