injector leak
injector leak
Postby shaungriff » Tue Mar 21, 2006 11:01 pm
is there a known problem with fuel leaks on injectors ? the van is a Y reg 2litre 75 ps. the fuel appeared to be leaking from where the steel pipes bolt on to the injectors. the unions have been nipped up but theres still a slight leakage (according to the owner). cheers shaun
shaungriff
Postby Nighthawk » Tue Mar 21, 2006 11:09 pm
The pipes have probably been undone and then retightened at some stage. They are not supposed to be reused because the end of the pipe deforms and creates a seal against the injector and the nut.
You can try and undo the nut and reseat the pipe on the injector before tightening it up, but the old course of action recommended by FMC is the replacement of the pipe set.
Thats about £80 worth of pipes :shock:
Nighthawk
Postby MrMPuk » Tue Mar 21, 2006 11:10 pm
PTFE tape then!
Postby shaungriff » Wed Mar 22, 2006 8:53 am
thanks nighthawk, that sounds right - the owner had the van in the local ford dealer for a fuel starvation problem which they fixed, however he rang me a few weeks later to do a service & loss of power. i found the intake hose between turbo & manifold adrift due to clips left loose ! also notced fuel leak on a couple of injectors - the unions were quite loose on the ones that were leaking so i guess the garage had undone them then not renewed the pipes ? thanks again shaun
shaungriff
Postby FredTransit » Wed Mar 22, 2006 4:07 pm
MrMPuk wrote:PTFE tape then!
Would PTFE tape work? Is it diesel resistant?
FredTransit
Mk2 Trannyist
Postby 100ps_drw_hicube » Wed Mar 22, 2006 4:40 pm
i have used it on a oil line once and it held out :)
100ps_drw_hicube
Transit Abuser!!
Postby FredTransit » Wed Mar 22, 2006 4:59 pm
You live and learn, always good to know these things.
FredTransit
Mk2 Trannyist
Postby 100ps_drw_hicube » Wed Mar 22, 2006 5:03 pm
electrical tape works well on oil lines too :lol: :lol: :lol: my p.a.s pipe is still holding out after 5k :shock: a nice cheap 99p fix :lol:
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Wed Mar 22, 2006 7:01 pm
I use PTFE tape on everything apart from Oxygen lines as it explodes!
Postby FredTransit » Wed Mar 22, 2006 7:04 pm
MrMPuk wrote:I use PTFE tape on everything apart from Oxygen lines as it explodes!
That's not good, how do you know this??? :lol:
FredTransit
Mk2 Trannyist
Postby MrMPuk » Wed Mar 22, 2006 7:06 pm
Doing what I do Fred it's one of the things you get taught!
Postby FredTransit » Wed Mar 22, 2006 7:08 pm
MrMPuk wrote:Doing what I do Fred it's one of the things you get taught!
it sounded like you ahd been on something like Mythbusters or summat! :lol:
FredTransit
Mk2 Trannyist
Postby MrMPuk » Wed Mar 22, 2006 7:11 pm
There is a special PTFE tape which comes in a blue container for oxygen.
Postby FredTransit » Wed Mar 22, 2006 7:13 pm
MrMPuk wrote:There is a special PTFE tape which comes in a blue container for oxygen.
Once again, i live and learn! This Forum is a mine of information!
FredTransit
Mk2 Trannyist
Postby gazza » Thu Mar 23, 2006 3:02 am
getting slightly off topic but heres some more on the p.t.f.e front, fine on water, compressed air and most oils and some chemicals, but it is not recommended on any gas instalation as gas degrades the p.t.f.e, use loctite threadseal instead.
gazza
