Misting windows ?
Misting windows ?
Postby couchcommando » Sun May 07, 2006 1:40 pm
At the first hint of damp outside the windows mist up almost instantly.
Do yours ? the ventialtion system cannot clear them I have to resort to the heated screen and aircon.
If you don't have this option what do you do ?
couchcommando
Postby transitgeoff » Sun May 07, 2006 2:51 pm
never had this problem in any of mine, but i aint got any with heated screens or aircon :D
transitgeoff
Postby madmark » Sun May 07, 2006 3:02 pm
:? alot of vehicles mist up if they have aircon ,no idea why but its a thing i have noticed with the cars i have had with it! :?
Postby transitgeoff » Sun May 07, 2006 4:01 pm
spot on there Mark, my Hilux does that, maybe the cold pipes cause condensation??
transitgeoff
Postby AndyG » Sun May 07, 2006 9:39 pm
Could it be you only do short journey work :?:
Postby couchcommando » Tue May 09, 2006 5:36 pm
it's on all journeys but I think the answer is because of the air con, dunno why but thinking back my trafic did it too and that had air con !
couchcommando
Postby FredTransit » Tue May 09, 2006 6:44 pm
The only Mk2 that this happened to was the amby. I would walk past and it would look like somebody was having a snogging match in there :lol: :roll: . On closer inspection, there was a 1p sized hole in the roof, probably from something being removed, directly above one of the flouro lights. The light fitting was catching the water, then it would steam off when the roof heated up. Check you haven't got a slight leak somewhere it's not seen.
FredTransit
Mk2 Trannyist
Postby WINDSCREENGUY » Tue May 09, 2006 7:04 pm
how about checking your pollen filter it might need replacing
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Postby MrMPuk » Tue May 09, 2006 7:07 pm
Any vehicle with air con will cause misting on cold glass due to the amount of condensation that collects on the cooling coil.
Postby transitgeoff » Tue May 09, 2006 7:26 pm
i notice it more when the sun comes out and the vehicles already warm :?: oh and whats the cooling coil :)
transitgeoff
Postby MrMPuk » Tue May 09, 2006 7:28 pm
Cooling coil (evaporator) is the bit the cools the air and as we all know moisture condesates on cold surfaces.
Postby transitgeoff » Tue May 09, 2006 7:41 pm
cheers :D a/c is not my thing, i know its nice on those long hot summer days that are coming tho 8) but i still think sliding front doors are better 8) 8) 8) 8) 8) 8) 8) 8) :D :D :wink:
transitgeoff
Postby topdogs » Wed May 10, 2006 11:13 pm
The trouble I have with aircon is that I run it on a hot day and get the bus nice and cool and as soon as people get in thet open the bl**** windows!
topdogs
