Mark 17 wrote:Hi - got a couple of Q's, hope you can help.
Changing my N reg mk5 in a few days for a mk6 on an X or Y plate. I definatley want a swb low roof but I am a bit behind the door when it comes to the model spec on these Transits.
Do they all have PAS & central locking as standard?
Are they all powered by the 2.0 TD engine?
What is the difference between T150, T260, T280 ect?
Any advice would be very much appriciated.
Thanks guys.
P/Steering standard C/Locking standard but some grey imports no R/Control.
2.0 engine FWD 75PS/100PS (T150?) T260=80 T280=100 T300=120 equiv.
2.4 engine RWD 90PS T330=150 equiv. (16"Wheels) Higher floor inside like MK5 .
And don't worry too much about the ultra thin body panels, it's normal
Any rust will result in a hole in no time.
Early fwd s had a problem with air getting in at the fuel filter assy resulting in non starter. Should be cured by now.
RWD s wheel nuts used to come loose
So all of these should have been sorted. You may even see those little bright green plastic arrows on the nuts to allow a quick visual check
And ignore my signiture as it doesn't apply to a MK6
Hope this helps
