Front Fogs
Front Fogs
Postby VJ 6 Aus » Mon Jun 26, 2006 11:14 am
Motorwise wrote:I've got front fogs on mine the switch just pulls out two notches instead of one - same switch on focuses etc if you have them over there they more commonly have that option - hope it helps
Hi everybody I know there are several threads in here regarding this fitment and have noted that the Mk6 escort and Transit fogs are the same
I have ordered the TIS disc just waiting for it to arrive. Today I went to our friendly Ford dealer on another Transit related matter and enquired about Fogs and switches guess what, shown in the parts list but marked "not serviced item in this market" they actually show
4 different configuration switches only the basic headlight rear fog control is available.
we don't get the height adjust headlights here nor do we get the panel dimmer switch.
I then checked my lovely wifes 2.0 Zetec Focus 03 model and it has the switch with Front and rear fogs and dash dimmer but is a totally different shape (almost pear shape) to the 05 transit switch so I thought I will have a look at an 05 Focus ( latest shape with the big wheel arches etc) it has the same configuration Front and rear fogs and dimmer but is a much squarer Flater switch. Now I am successfully confused. It is unlikely that Aussie foci got a totally different dash to the rest of the world. So can anybody clear up the switch myth 100%, would it be the escort with the same switch perhaps? ( which we don't get over here!!!)
and would one of you be Kind enough to either get me the part number for the non height adjustable switch with front and rear fog and dash dimmer to suit MK6 Transit as I have allready checked and the wiring is in place I can source the lights of flea bay I just need the switch.
Ric
VJ 6 Aus
Postby belly » Mon Jun 26, 2006 6:54 pm
just a word of warning mate! i sourced the correct switch manual height adj front and rear fog type , escort fog lights plugged it all in all the wiring is there, but nothing nada not a bean :cry: and ive searched all the fuse and relay boxes positions nothing not even listed :shock: although i dont have a tis disc so if you get any luck on that please please let me know :D oh and be carefull cutting the holes out on your bumper i buggered mine right up ended up buying correct ones with holes cut out already :evil: plus when you buy the lights make sure you get the little angle bracket one per side!! mine came with two from the same side so had to adjust it with a vice and a high impact tickle stick :lol: good luck mate i wouldnt do it again tho :?
belly
Kaiser Chief
Postby Nighthawk » Mon Jun 26, 2006 8:10 pm
Just because the part shows on microcat or ecat as being not for your market, if the partsman takes out your chassis details he can still see the part number.
The ford ordering screens will allow him to order the parts, but your going to have to wait a wee while for them to turn up down there.
:lol:
Transit.........Job done
Nighthawk
Postby VJ 6 Aus » Tue Jun 27, 2006 12:41 am
Nighthawk wrote:Just because the part shows on microcat or ecat as being not for your market, if the partsman takes out your chassis details he can still see the part number.
:lol:
That would be If he was a nice parts man unfortunately most of ours hate their jobs and make sure everybody knows it!!
VJ 6 Aus
Postby 100 T280 » Tue Jun 27, 2006 8:15 pm
belly wrote: plugged it all in all the wiring is there, but nothing nada not a bean :cry: and ive searched all the fuse and relay boxes positions nothing not even listed :?
You will probably have been through all this, but just in case:-
Passenger compartment fuse box, fuse no. 203(20A yellow). This is on the second row from the bottom, second from the right hand side. (Note the six rows are staggered) According to the TIS and vehicle handbook for my '02, there is no relay specific to the fog lamps. Try testing for output at the headlamp switch, the frong fog lamp feed is the Orange wire with yellow tracer. Rear fog lamp feed is the green wire with red tracer
HTH :)
'02 100 T280 SWB Exec. FWD Medium Roof 2.0 DuraTorq TDdi 100ps
College Blue, Alloys, Eberspächer, Twin Batteries, Single Seat,
"Park Distance Control", AirCon, Rev. Counter, 7000RDS.......
100 T280
Postby Valsheda » Wed Jun 28, 2006 9:46 am
I think the front foglights do look nice, but my worries would be the dreaded stone chips, i have seen so many vans 'n' cars with cracked fogs, it just seems an expensive hobby replacing them, wouldnt it be better to get an A-bar with with some nice big driving/spot lamps :?
Valsheda
Top Tourneo Owner
Postby belly » Wed Jun 28, 2006 7:25 pm
thanks 100t280 will try when ive got some time off :cry: prob give it one more go myself then if not a few ppl of here have offered to have a look for me :D to which a reward of beer is always offered :lol: i stuck some clear pvc sail repair type over my last car spots due too them being cracked regular :? the tape just kept them together tho didnt stop the regular occurerence of stones cracking them :?
belly
Kaiser Chief
Postby VJ 6 Aus » Sun Aug 13, 2006 8:28 am
Righto, after a bit a cutting and Dremeling to get the moulded bits out of the bumper very carefully did'nt want to scratch the new paint ( I know should have cut then painted!!! {see thread Transit Parts UK} :( ) made a couple of little ally brackets found the leads plugged em in pulled the Rhs dash panel off changed the switch hunted down the test light switched on the ignition turned and pulled the new headlight switch BINGO we have front fogs wish I had tried em before wasting 1/2 an hour looking for the test light :oops: anyway all good, put a 9mm ply floor in yesterday with sound deadener as used under floating floors that a mate had lying around
going to make a bulkhead tuesday night with a 500mm sleeper/bench behind the seats and a big pull out drawer under opening into the back.
Its getting there!!!! slowly :wink:
VJ 6 Aus
Postby belly » Sun Aug 13, 2006 5:44 pm
well done mate 8) lucky you tho just worked straight off :D mine still not workin and have no spare time to sort at the mo :x
belly
Kaiser Chief
Postby VJ 6 Aus » Tue Aug 15, 2006 3:10 pm
Hey Belly I know this sounds stupid and just slap me upside the head for even thinking it but one of my Fogs came without the globe fitted :shock: , you checked both of yours under the rubber boot didn't you............ of course you did I'm an idiot who wouldn't do that :wink:
VJ 6 Aus
Users browsing this forum: Google [Bot], Google Adsense [Bot], T350camper
