shock absorbers!
shock absorbers!
Postby whooshbang » Wed Jun 28, 2006 6:49 pm
Also, upon taking my beloved transit for MOT, it failed on shock absorbers? again the specifics are coming tomorrow. I was wondering if the absorber itself, comes as a complete unit or they are a internal and require spring compression tool to replace. That's of course if it's absorbers at all? someone mentioned to me that it could be bushes? Again, not too sure as i don't know the specifics.
I have had a search on here but can't find any info on this, any advice much appreciated.
thanks
2003 125 T350 MWB HT 2.4 RWD
whooshbang
Postby MrMPuk » Wed Jun 28, 2006 6:51 pm
I'd wait and posts the questions when you are sure what it is!
Postby whooshbang » Wed Jun 28, 2006 6:54 pm
MrMPuk wrote:I'd wait and posts the questions when you are sure what it is!
of course. just getting the post rolling. i will update tomorrow, honest.
whooshbang
Postby motorwise » Wed Jun 28, 2006 7:00 pm
they could be leaking or weak or the bushes on the rears could be worn out
on these the fronts are struts requiring a spring compressor and the rears are just conventional shocks
hope it helps
http://www.motorwise.net
motorwise
Postby whooshbang » Wed Jun 28, 2006 7:05 pm
motorwise wrote:they could be leaking or weak or the bushes on the rears could be worn out
hope it helps
brilliant. I had noticed an occasional knocking when driving over those dreaded speed bumps, from the front it seems to be coming. and upon driving it accross a field the knocking was quite prominant, due to the roughness of the field no doubt.
thanks for the struts info also.
whooshbang
Postby whooshbang » Thu Jun 29, 2006 10:25 am
alrighty then, the inspector has been in touch;
n/s front shock leaking
o/s rear shock leaking
hopefully this is not gonna be too expensive. i am told that the front shocks are inserts so the whole thing doesn't need replacing, just the insert itself. hope this wil bring the cost down a little.
I am awaiting a quote from Lex for this, i'll let you know what it comes to.
cheers
whooshbang
