2003 Duratorq 2.0L TD Lumpy & Losing Water When A/C Used
Postby RodneyTrotter » Tue Jul 04, 2006 9:15 am
Hi, my mates 2003 2.0L TD Duratorq seems to be running lumpy, no loss of power although he says " it doesn't pull like it used to....". Also ie seems to lose alot of water from the expansion bottle, he says, but only when he's running the air con........is this "normal"? His boss has just had her Operators licence suspended for 6 months so he may be looking to buy the van from her......if its all ok!!!! Thx in advance......
RodneyTrotter
Postby Two Transit Dave » Tue Jul 04, 2006 7:18 pm
I'm no expert on air-con but both my Transits have air-con and i dont think its in any way conected to the engine cooling water it does drain a fair bit of power so if there is something wrong with the engine perhaps the extra load of running the compressor showsw it up more.
Two Transit Dave
Postby AndyG » Tue Jul 04, 2006 7:44 pm
On my MK5 the aircon. activates a vacuum operated valve that stops any water going through the heater matrix :idea:
Your van could be giving signs of a blocked radiator :?: :idea: What's the temp. gauge saying :?:
Two Transit Dave is right in saying that the compressor does put an extra load on the engine :D
You can't have something for nothing :!: :D :lol: :lol: :lol:
Postby Two Transit Dave » Tue Jul 04, 2006 8:59 pm
Andyg I guess you can still use your heater and air-con combined on your van can't you because I quite often use the air-con with the heater to clear the windows of mist during the winter months.
Two Transit Dave
Postby AndyG » Tue Jul 04, 2006 9:08 pm
That's right :!: :D If the heat setting is in any other position than cold you end up with "climate control" so it doesn't freeze your ........ off :shock: :lol: :lol: :lol: :lol:
If I eat something hot in the van during winter, the aircon. clears those windows in seconds :!: 8) 8) 8) 8)
Mmmmmmm....
Postby RodneyTrotter » Wed Jul 05, 2006 9:40 am
Temp gauge always reads ok...........thx
RodneyTrotter
Users browsing this forum: ericjmoran2003, Google Adsense [Bot]
