belly wrote:i got a lead from Halfords which turns the signal from the spare/rear speaker outputs into two aux outputs then i found a switched live for the amp on/off
belly wrote:If you struggle to get one let me know and I can get one here and post it over it's made by autoleads !
MrMPuk wrote:No, that is an adaptor for fitting an aftermarket stereo.
You need an autoleads pc1-601 which is a Line Output Connector.
madbri wrote:can u put a link to this
Tran59 wrote: (obviously paying you for your trouble)
MrMPuk wrote:Probably be easier and cheaper to fit an aftermarket head unit.
Users browsing this forum: Google [Bot], knobby1
