Keys and Remotes
Keys and Remotes
Postby VJ 6 Aus » Sat Jul 22, 2006 2:14 am
Does anybody know if it is possible to program focus/ or any other ford for that matter key remotes to transit mk6 probably a silly question but I just like the idea of having the key and remote in one unit
Mr NightHawk anybody??
VJ 6 Aus
Postby MrMPuk » Sat Jul 22, 2006 4:28 am
Me and madmark were talking about this and came to the conclusion that it wasn't possible.
Postby transitgeoff » Sat Jul 22, 2006 7:47 am
yes it can be done ive got one mk6 on a focus all in one key :D has to be a blue chip mk6 Transit though no mk5`s :D if your local to me my man will do it for you, cut and programmed :D
transitgeoff
Postby MrMPuk » Sat Jul 22, 2006 7:48 am
madmark will be pleased!
Postby Nighthawk » Sat Jul 22, 2006 11:13 am
the all in one remotes will work as they have a blue chip "rolling code" system,
BUT
It's been proven to cause the starters to burn out through extended engagement because some of the keys make contact with the trim covers around the ignition switch and keep it in POS III
Transit.........Job done
Nighthawk
Postby VJ 6 Aus » Sun Jul 23, 2006 1:37 am
Thanks Gents, so a bit of judicious Dremelling around the end of the Key should sort out the Pos 111 issue shouldn't it??
and what about programming same as usual??
and Geoff Thanks for the offer but of all the accessories I am fitting water wings ain't one of em long drive to UK from Australia just to get a key coded......
" back in a minute Love .... just off to get a Key sorted for the new Truck .........in England"
Anybody have the correct remote part number
VJ 6 Aus
Postby Nighthawk » Sun Jul 23, 2006 9:47 am
They will program in the same manner as the normal fob.
The fouling issue didn't seem to affect every vehicle :eek:, so I would strongly suggest having a good look at the key when inserted in the ignition barrel.
You need to make sure that it's not touching on the metal of the barrel or the trim, so the key can spring back as you come away from the crank position.
NEW transit does have the all in one key.......but it's not the same as the old one and it's bright BLUE!!! to signify that it's one of the new fangled automatic charge type.
Nighthawk
Postby VJ 6 Aus » Sun Jul 23, 2006 10:08 am
Cheers ,
The Hawk saves the day again :D
VJ 6 Aus
Postby transitgeoff » Sun Jul 23, 2006 11:39 am
yes the locking bit programs the same as the old seperate fob but the chip still needs programing or you wont be going anywhere :lol: but still you will be able to get in and out of the van :D
transitgeoff
Postby RicMk6 » Mon Jul 24, 2006 2:28 pm
In case anybody was wondering VJ 6 Aus is now me for some reason I couldn't log in for love or money so after trying for 4 hrs :evil: I have set up a new user name
if it Floats, Flys,or Fornicates its cheaper to rent it
RicMk6
Postby FredTransit » Mon Jul 24, 2006 2:59 pm
RicMk6 wrote:In case anybody was wondering VJ 6 Aus is now me for some reason I couldn't log in for love or money so after trying for 4 hrs :evil: I have set up a new user name
Did you try asking Luke for your sign in details? Just reply by email to the thread notifications. Oh, and if you rethink the water wing option thing, I am sure you would be welcome at a run in the UK :lol:
FredTransit
Mk2 Trannyist
Postby RicMk6 » Mon Jul 24, 2006 3:18 pm
I have sent an email to the Admin but I'm an impatient barstard and understand that people have to do things like work for a living, thats what you get for being upside down I'm working while your sleeping and vica verca so I'm sure the admin will send me a little email whilst I'm snoring me head off as for a run in the UK did that in 04 went up to Newton Stewart for the Park Stages Rally and then down to Wales to Rally GB and to Donnington and Silverstone amazing the places you get to go without the Handbrake in tow :lol:
RicMk6
Postby FredTransit » Mon Jul 24, 2006 3:21 pm
billing's the place, in August! National Street Van Association, custom and other vans, the Forum will have a possy. I will be there. See the upcoming events section.
FredTransit
Mk2 Trannyist
Postby VJ 6 Aus » Wed Jul 26, 2006 8:50 am
Another stupid question is it possible to program new keys ( not remotes) if you only have one original key, the owners manual says no but what would they know you lot are lots smarter
VJ 6 Aus
Postby MrMPuk » Wed Jul 26, 2006 8:54 am
If you only have 1 key then you will either need to take it to a Ford dealer or a locksmith that can program them for you.
