winterheating wrote:So basically the RIM is another module inside the PCM
wertyu2007 wrote:Did op sort this ?
got similar issue , when van came to me after having vacuum pump fitted , it was turning over but a non start , the mechanic had all ready had a no start and cleared all codes and it ran , later it stopped running , I then checked codes got a B2139 PCM ID does not match between the PCM and PATS control , so after reading a post on here i reprogrammed the fuel pump and it started up , thought it was fixed but got call today saying its happened again 20 miles later.
I got to visit it tomorrow again would like some ideas.
all i know is what ive told you above.
wertyu2007 wrote:I could see that my friend but still very very relevent to my issue........
wertyu2007 wrote:Thats a strong possibilty.
It ended up being bad wiring to fuel pump module , a lot of advice gained from this forum so thanks FTF .
