MrMPuk wrote:The frame on the twin seat is part of the seat.
stephenferguson wrote:the double will bolt in the same place as the single but as mentioned you may need the bolt to bolt the seat belt unit to the floor, just make sure you disconnect the battery a few mins before you unplug or plug in any airbags...
Also if you arent putting the airbag back in i think you have to inform the insurance.
If ford cant omit the airbag you can get a resistor to go accross the airbag plug terminals which will make the vehicle think that its still there and keep any lights off the dash.... Not sure of the size of resistor required tho.
fedup2 wrote:Someone must have gone down the route with first hand info??
