jumps out of 2nd gear
Postby shaungriff » Wed Aug 16, 2006 4:50 pm
my mates got a transit 2.0 tddi 75bhp on a w reg. when he goes from 1st to 2nd it sometimes jumps out of 2nd. is there any known faults that cause this on these vans such as linkage/cable adjustment or do they just have weak gearboxes ?? thanks shaun
shaungriff
Postby MrMPuk » Wed Aug 16, 2006 4:58 pm
Yeah, sounds like cable adjustment to me.
Postby FredTransit » Wed Aug 16, 2006 5:11 pm
If it only does it in 2nd I would have said the gearbox, but you would know better than me with the later stuff.
FredTransit
Mk2 Trannyist
Postby Nighthawk » Wed Aug 16, 2006 9:25 pm
W is a very early reg for the fwd
I'd be looking at the cable first, the outer cables on the early ones were prone to stretching and giving selection issues when trying to get 2,4,rev
I'd start by removing the cable (grey) abd checking the crimped metal ends, if you can see the inner strands of the outer sleeve it's goosed.
if it's ok, refit it and adjust it to spec,
release the adjuster on the cables
make sure the box is in neutral
fit a locking bolt though the hole in the lever bracket
re fasten the adjusters
If selection is still bad, you need to move closer to the box
does the gear select fully if you use your hand on the linkage?
is there any slack between the detents on the gearbox selector linkage?
if so, report back and i'll give further assistance
Transit.........Job done
Nighthawk
Postby 100ps_drw_hicube » Wed Aug 16, 2006 9:44 pm
builder friend of ours is on his 4th gearbox in his 51 reg :twisted: :twisted: :twisted: they dont like weight those fwd box's :twisted: :twisted: now i see they do fwd in higher weight capacity :shock:
100ps_drw_hicube
Transit Abuser!!
Postby shaungriff » Wed Aug 16, 2006 10:50 pm
thanks everyone, i'll check it out asap
shaungriff
Postby FredTransit » Thu Aug 17, 2006 10:51 am
Don't like the wieght?? What's the point of a van if it can't take any wieght?
FredTransit
Mk2 Trannyist
Postby AndyG » Thu Aug 17, 2006 11:55 am
100ps_drw_hicube wrote:builder friend of ours is on his 4th gearbox in his 51 reg :twisted: :twisted: :twisted: they dont like weight those fwd box's :twisted: :twisted: now i see they do fwd in higher weight capacity :shock:
They're mad :!: (Or maybe appealing to the ones that insist on FWD :?: )
:idea: Does give you a few inches in height inside and can make a difference if you carry something specific I suppose :!: :D That wouldn't go in if it was RWD :idea: :?:
Postby 100ps_drw_hicube » Thu Aug 17, 2006 5:02 pm
FredTransit wrote:Don't like the wieght?? What's the point of a van if it can't take any wieght?
to keep up with these crappy french attempts at a van :twisted: :twisted: :twisted: there ok but not much good when your a builder :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby djdarch » Sat Aug 19, 2006 5:22 pm
When i first got my van a couple of months ago this hapened to me , basicly its a trip down to the dealers and get a new cable £60 ish. Its pretty easy to fit once you work out how the clips attach.
I am not that mechanically minded but i did it myself no probs.
djdarch
Postby shaungriff » Tue Aug 22, 2006 5:28 pm
well cable seems ok, you can't push it any further into 2nd even if you disconnect the cable. i noticed the linkage goes in & out of gear really easy like the detent springs are weak ? i drove it round but couldn't get it to jump out for me. he reckons when it does it you can feel trying to push out of 2nd against your hand so sounds like the box.
shaungriff
Postby Nighthawk » Tue Aug 22, 2006 7:45 pm
the selector housing can be a problem, and can be removed from the box and repaired if needed.
the syncros don't have that much pressure on their detent springs.
is there any free play in the gear box linkage?
Nighthawk
Postby shaungriff » Tue Aug 22, 2006 10:38 pm
not really much play. owner reckons it seems to do it more when he's been driving a while. working the linkage by hand it just seems to go in & out of second too easily to me. i drove it a couple of miles banging foot on &off throttle but it wouldn't jump out. owner says when its playing up he has to drive with hand on gear stick to keep it in 2nd & he can feel it trying to push out of gear. thanks shaun
shaungriff
drops out of second gear
Postby trnsitvanman » Sat Aug 26, 2006 10:03 pm
I had the same problem with my 2001 front wheel drive t300 .
took it to Busseys in norwich.
they fitted both cables plus the bit that sits under ther gear leave selector.
this cost me £265.00 but well worth the money because now its perfect plus they give me a 12 month warranty on the repair.
but yours might still be a different fault.
Motor bike are fun but Dangerous Too
trnsitvanman
Postby dangeeeeerousss » Sat Aug 26, 2006 10:06 pm
hi i know its not the same veichle but i had the same problem on a ford galaxy and that turned out to be a gearbox mount thought it might of been worth a check :idea:
dangeeeeerousss
