Filling that previously dug out hole syndrome...
Postby transitdude » Sat Aug 19, 2006 8:09 pm
Hi,
God, I'm asking so many questions at the moment!
Doing the oil and coolant change has got me stumped recently.
Oil capacity is 6.5L. Extracted the oil and filter and replace with new items. Could only get 5L back in.....
Emptied out the coolant so no more was dripping. User manual stated 10L dry capacity but could only get 6.4L back in.....
Am I doing something fundamentally wrong when performing these bits of maintenance?
Cheers
Frank
transitdude
Postby AndyG » Sat Aug 19, 2006 10:39 pm
You need to run the engine for a bit so that the oil filter fills up :idea: :wink: And as for the cooling system, did you empty the block :shock: :?:
Postby transitdude » Sun Aug 20, 2006 10:13 am
yeah, I did both just after coming back from a run.
I assumed for the latter (coolant change) that with the engine being hot the thermostat would still be open allowing any previous fluid around the engine to filter out? - maybe I was wrong..
Cheers
Frank
transitdude
Postby AndyG » Sun Aug 20, 2006 4:10 pm
To get ALL the water out you'll have to remove the engine heater matrix and radiator and give them a good shake :!: :shock: Highly unlikely :lol: There will always be water left in the system :!: :D
When changing the oil, the drain plug must be the lowest point of the sump or again you will be leaving old oil in the sump :idea: You can never get all the old oil out :D
Just one of those things :wink:
Postby Guy88 » Sun Aug 20, 2006 4:22 pm
if you did the oil after a run there will still be oil around the engine. you need to let it settle for about an hour. this way it will still be warm but it will be mostly in the sump :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sun Aug 20, 2006 4:41 pm
Guy88 wrote:if you did the oil after a run there will still be oil around the engine. you need to let it settle for about an hour. this way it will still be warm but it will be mostly in the sump :D
It really needs to be as hot as possible and it will then carry out any sh*t with it :!:
So I guess that the best way is to pull up in the evening after a long run and drain it (with the oil filler cap off) over night :idea: This should give you the best oil change :D
Postby MICKA404 » Sun Aug 20, 2006 5:31 pm
same thing happened to me, drained oil after a run left it for 2hrs on level ground, put new oil in and it was about 3/4 in above the full mark had to drain some off, is this common on mk 6 or should the engine be flushed as well when oil is changed.
mike
I ALWAYS PASS ON GOOD ADVICE. IT ISTHE ONLY THING TO DO WITH IT. IT IS NEVER ANY USE TO YOURSELF
MICKA404
Postby transitdude » Sun Aug 20, 2006 9:01 pm
the only vehicle i've managed to drain nearly all oil out of was a Nissan Micra. I used my 3 Tonne trolley jack to lift the front up so the car was 45 degrees in the air. Looked at bit crazy but extracted those lumpy bits out of the bottom. :-)
Cheers
Frank
transitdude
Postby AndyG » Sun Aug 20, 2006 9:06 pm
:idea: Maybe the sump has been redesigned so that five litres will do the trick :?: :idea: :D
