Milemuncher wrote:I've got another even more annoyance with the central locking. If when you unlock the cab only then start the engine, you subsequently cannot unlock the rear doors with the fob unless you switch off the engine !
I suppose it is the same as the fuel cap, it's to stop you leaving the key in the ignition.
PMeyer wrote:Milemuncher wrote:I've got another even more annoyance with the central locking. If when you unlock the cab only then start the engine, you subsequently cannot unlock the rear doors with the fob unless you switch off the engine !
ha ha - this p1sses me off too! I unlock the cab, start her up - pull away to the gate at the depot....only for security to leap out of his office and demand a quick check in the back......grrrrrr! Engine off, unlock back, engine start again...GRRRRRR!
Users browsing this forum: Google [Bot], Trev_
