Mk7 Fwd 2.2 130 ps swb IMAGE thread
Postby fedup2 » Fri Mar 18, 2011 5:52 pm
Ive been thinking,yes it hurt :(
Ill though now im getting to know my way round my van in the past when ive needed help pictures would have been a big help so what about an image section,maybe others can create similar ones to refer to if needed.
Ill keep adding to this one if people think its worth while but heres a few.
Airbag and heated seat wiring blocks
Tyre and specs
heated seat eliments
Airbag resistor
Belts
Filter housing
gearbox
Maf sensor
Map sensor
Map sensor housing
fuel rail left
Jump post
Turbo
Injector pair
Engine top
Launch x431 owner ;)
fedup2
Re: Mk7 Fwd 2.2 130 ps swb IMAGE thread
Postby fedup2 » Fri Mar 18, 2011 5:56 pm
New map sensor
fedup2
Postby fedup2 » Fri Mar 18, 2011 6:01 pm
Egr
fedup2
Postby fedup2 » Fri Mar 18, 2011 6:02 pm
fuel rail
fedup2
Postby fedup2 » Fri Mar 18, 2011 6:03 pm
Airbag
fedup2
Postby fedup2 » Fri Mar 18, 2011 6:05 pm
Airbag ribbon steering angle sensor
fedup2
Postby fedup2 » Mon Jun 27, 2011 6:05 pm
fedup2
Postby fedup2 » Sun Nov 06, 2011 4:42 pm
Rear brakes
fedup2
Postby V184 » Sun Nov 06, 2011 5:01 pm
Your a fan of copper slip then :lol:
V184
Postby fedup2 » Sun Nov 06, 2011 5:05 pm
Anything that might make things last a touch longer :)
fedup2
Postby V184 » Sun Nov 06, 2011 5:13 pm
you should have covered the disc in it then !
V184
Postby blue estate » Sun Nov 06, 2011 5:16 pm
V184 wrote:you should have covered the disc in it then !
:shock: Aren't ford brakes bad enough :lol: :lol:
blue estate
Postby fedup2 » Sun Nov 06, 2011 5:18 pm
I did :)
fedup2
Postby V184 » Sun Nov 06, 2011 5:26 pm
i had a fwd one & they were shocking ! the 140 jumbo i have is spot on, just kills egrs :lol:
V184
Postby blue estate » Sun Nov 06, 2011 5:42 pm
My 60 reg fwd did both front and rears in 25k and were crap :shock: but as you say the jumbo one's are a lot better :wink: i don't need to keep changing under pant's if i have to brake suddenly :lol: :lol:
blue estate
