on the top of the dash you have the lid of a box with a latch on the front, open the lid, next to the latch theres 2 screws, take these out and the hole box unclipps, the aux box is under there
2005 Ford F250 Super Duty 1992 MK3 ambulance 1980 A Series crew cab 1984 A series RB44
it should have a white wiring dig on underside of the lid on the compartment as well, and a 16 pin delphi female connector tucked away just behind glove box. if you decide to remove lid to check and havent done it before it can take a fair pull to get it off once you remove the two screws at front. ta andy
really ive never seen one there and ive worked on transits all my life and had the whole dash out a mk7 transit????? the only fuse box or bcmii is located behind the glovebox on the left hand side, what do you want to know for??????????
just goes to show doesnt it that ive worked for ford man and boy and havent seen one or heard of one, a ford tech is just like a mushroom, kept in the dark and fed s**t
cant see extra fuse box with cubby box out but there is 2 wires to where a left hand drive auxilery cigerette socket would go is it just a case of butting a new fuse in the fuse box and a cig socket to use these wires
transit tractor cant quite picture what wires you are on about . are the wires you are talking about fairly small wires on a 2 pin connector. just wondering if you are looking at the wires for an aux input to the radio unit. it fit into a mounting hole on the right of the passenger storage compartnent ta andy
