Heater Blower only working on speed 4
Postby stubbsys@hotmail.com » Wed Jan 09, 2013 10:09 pm
Hi all ive a 06 plate transit connect ive seen on other forums that replacing the resistor normally fixes the fan but ive tried this without success is there anything else i could try please help
Re: Heater Blower only working on speed 4
Postby gt_addict » Wed Jan 09, 2013 10:22 pm
If the resistor works for a moment then stops and you go back to only working on level 4 then its more than likely the motor itself causing the resistor pack to blow. I had the same issue on a mates focus.
gt_addict
Postby liteace » Thu Jan 10, 2013 12:06 am
stubbsys@hotmail.com wrote:Hi all ive a 06 plate transit connect ive seen on other forums that replacing the resistor normally fixes the fan but ive tried this without success is there anything else i could try please help
The fan motor is fed with a constant +12volt feed when the ignition is on, speed 4 is direct switch to earth, speed 1,2 & 3 run through the resistor then are also switched to earth, inside the main resistor unit there are 3 resistors connected in series, speed 1 run through all 3 resistors, speed 2 runs through 2 resistors and speed 3 runs through 1 resistor then down to earth. Earth pins 1,3 & 5 ONE AT A TIME of the fan blower switch and see if the blower works on the lower speeds, if it does replace the switch
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby electric » Thu Jan 10, 2013 12:51 am
Check the plug that goes to the resistor they have a habbit of over heating, ford supply a replacement plug if it is burnt
2005 T220 LX TDCi Rolling on 18 inch Jaguar alloys
http://www.acornautoservices.co.uk
Servicing and Repairs, MOT testing, A/C systems regassed
electric
Postby g-man » Thu Jan 10, 2013 12:58 am
you learn something new everyday 8)
g-man
Postby stubbsys@hotmail.com » Fri Jan 11, 2013 12:07 am
Thanks all i will have a look over the weekend see what i can see and let you all know
