Transit connect 1.8 tddi
Postby peterrrl » Tue Sep 08, 2020 10:53 pm
hi as far as I know it ran out of fuel and won't start.
I changed the filter filled it and still not starting
I've tried cracking off injectors and turning over with no success
Also tried a primer bulb got fuel to the filter but I don't know if I was doing it right as still not starting any help appreciated thanks
peterrrl
Re: Transit connect 1.8 tddi
Postby peterrrl » Wed Sep 09, 2020 8:38 pm
Been trying tonight to get it going again and it now won't crank when key is turned all that happens is a click and nothing else
peterrrl
Postby karl » Wed Sep 09, 2020 9:05 pm
charge battery
if that doesn't work you may have burnt the starter motor out :(
always fill the filter first with fresh and you wouldn't have this problem
karl
Tranny Lover!!!
Postby peterrrl » Wed Sep 09, 2020 9:17 pm
karl wrote:charge battery
I tried a different battery and had it on jump leads to my car, also I did fill the filter with fresh fuel after changing but it wouldn't draw anything from the tank it seemed
Was thinking to try and drag it tomorrow to bump start it (tried it with 3 of us pushing it and nothing) but don't know if I should do that as never done that before
Hoping I haven't wrecked the starter motor as dont really want to change that
peterrrl
Postby karl » Wed Sep 09, 2020 9:27 pm
make sure all fittings are on correctly, any dash lights on engine management etc, personally wouldn't tow, last resort would be run it up on brake cleaner with a injector cracked off, ps i know il get slagged of for this advice but always works :lol:
if does not run on brake cleaner i would suspect fuel pump has failed
karl
Tranny Lover!!!
Postby peterrrl » Wed Sep 09, 2020 9:31 pm
It did start on easy start i know what is said about that lol
No dash lights, I primed it with a hand bulb and got fuel from the tank to filter and up to the end of the pipe that goes to the pump but then it stopped cranking so I don't know if it would have started now but didn't when trying to bump it so I don't really know what to do from here really. I will charge the battery tomorrow
peterrrl
Postby peterrrl » Thu Sep 10, 2020 9:41 pm
Tried with a fully charged battery and still no success
peterrrl
Postby karl » Fri Sep 11, 2020 12:03 am
Sounds like starter motor
karl
Tranny Lover!!!
Postby peterrrl » Tue Sep 15, 2020 4:37 pm
karl wrote:Sounds like starter motor
Shame think we broke it then
peterrrl
