Hi all, newbi here, got my self a Mk1 (55 plate) connect LWB high top, a few weeks back, and found a water leak so removed the dash to fix it, all going well until I went to refit the steering wheel to the steering column. As I put the wheel back on the column calloused into itself, no ball bearings appeared. Is it possible to reset the column?
I was thinking a long bolt and nut and wind it out, but I have noticed that the plastic spring carrier on the back of the Calais blue section doesn’t seem to be sitting correctly... ie the tabs don’t seem to be going back into the tube properly...
Any ideas suggestions... or do I need to buy a replacement from a breaker????
Tom
