INTAKE AIR SYSTEM LEAK
Postby AlinaDaut » Tue Aug 16, 2022 1:10 pm
Hi,i have a FORD TRANSIT CONNECT 2016,1.5 74KW,and i have problems with the acceleration,i mean it cuts off after 3000rpm and on the tester gives INTAKE AIR SYSTEM LEAK,cod P2279,i have changed the Air mass sensor and the throttle body and still the problem exists,my hoses are ok,the intake manifold ok,the intercooler ok,but there is still an air leak and i can't find it.someone with the same problem and maneged to fix it?sorry for my grammar mistakes i am from Romania :D
AlinaDaut
Re: INTAKE AIR SYSTEM LEAK
Postby p2thed » Sat Aug 20, 2022 8:11 am
Very common leak from the boost hose on the driver side, remove hose and check the underside for a small slit, you wont see it without taking the pipe off
p2thed
