engine cranks but won't catch -any help appreciated!
Re: engine cranks but won't catch -any help appreciated!
Postby sparkybandit » Fri Jun 09, 2023 9:52 pm
new video - shims all out of kilter or is it evidence of a timing issue?
https://www.youtube.com/watch?v=Db_JpAJC7cA
sparkybandit
Postby metalworker0 » Fri Jun 09, 2023 10:54 pm
All shims must go back in the same place they got taken out of
if you had new valves .....then you need to put a suitable shims in that provide the correct clearance ...the originals may not be right for a new valve
if you reground the valves ..it will require re-shimming with thinner shims
if you put the valves back in the wrong places - it will require re-shimming with thicker or thinner shims
measuring the clearance should be done with the point of the cam lobe pointing strait up on each one.
The shims are available on ebay ......you need to do some accurate measurements and
then use a calculator and work out what to buy
by putting the slack shim into one you'll be able to work out the difference and order new one or swap one of the others.
Shims may have the measurement on them ...but after running and the cams shaft running over them and wearing them , this measurement will not be the same ..so you need a vernier caliper ..or better still a micrometer to measure the shims.
Only brand new shims will be what they say they are .
all shims are common to lot of ford diesels ..not just the connect .
If you had all the valves out ....when assembling the head ..its then that you'd be working out if the clearances are right .
If you had a valve grinding machine ..it has a fixture for grinding the top of the valve stems.........then on some you could just do that .......
note: grinding the top of the valve stems can only be done on a dedicated machine ...not on a bench grinder! and of course can only be done with the valves out.
all the best..mark
Postby sparkybandit » Fri Jun 09, 2023 11:34 pm
I replaced all the valves with new and re-lapped them of course,and I am sure i put the shims back in their right place but i could have made a mistake.
I'll have to bite the bullet and measure the gaps up and note it all down and, when i take the camshaft out, see if there is something glaringly obviously wrong with the order i put the shims in.
I'll do what you suggest and turn the lobes so they're pointing skyward when i measure.
In light of the fact that all the inlets are too tight, you don't think it could be related to a timing issue? or is this issue i've discovered solely related to the shim thickness and nothing to do with the timing belt?
I'm trying to work it out in my head weather the coincidence of all of the inlets being tight is a symptom of some sort of timing error i've made? or is it just a plain simple fact the shims are wrong for the new valves?...i'm shocked the difference made by using new valves has made to the tolerances
sparkybandit
Postby metalworker0 » Sat Jun 10, 2023 12:06 am
All new valves ...means original location of shims is null and void
all have to be measured ...and all may have to be re-shimmed
if you are lucky you nay end up with 1 or 2 that you can use again.
a ford dealership may have a collection of second hand ones for servicing ..they may let you swap some of yours for theirs ..IF THEY ARE NICE!
i think there is a 90 percent chance that this is the main problem!
Postby sparkybandit » Sat Jun 10, 2023 12:21 am
Hope so. Sods law van will sell on Sunday but at least new buyer has something to go on.
provided i don't melt in the heat tommorow i'll see how much i can get done. :D
sparkybandit
Postby metalworker0 » Sat Jun 10, 2023 7:10 pm
looks like you need a tool
Postby metalworker0 » Sat Jun 10, 2023 8:24 pm
These tools are so you can do the job quickly and without removing camshaft ....and are as rare as hens teeth
Postby sparkybandit » Sat Jun 10, 2023 11:48 pm
You just beat me to my question about tools :D
https://youtu.be/RJ4G8wAa3pA
sparkybandit
Postby metalworker0 » Sun Jun 11, 2023 12:37 pm
well it depends on how much you are paying for these shims that will be useless after you've done the measurement.
if its less than say £2 each .....then worth getting them
Postby sparkybandit » Mon Jun 12, 2023 2:04 pm
Ford dealership want £15 per shim.
Found a chap on e-bay ,he's sending me four of the thinnest he's got to try and if they work send him some £20,can't ask fairer than that.
3.5mm is the thinnest for this engine apparently,he's sending me a 3.55mm so i can use that as a guide to work out the rest,it don't matter if she's tappety it's just to see if she breathes into life.
sparkybandit
Postby Boghopper » Mon Jun 12, 2023 4:52 pm
Have you actually, physically measured these new valves and compared the total length of the new ones to the old ones? Something here seems really odd.
I just wondered, when you had your head off did you mic up the thrust faces on the bores to check that they are not worn; can't remember exactly what their limit is 82.5 or something?
Boghopper
Postby metalworker0 » Mon Jun 12, 2023 6:26 pm
well they are not just common to ford , they are common to a lot of cars ...
well according to ebays search ....dont know if you can trust it though
and on ebay they are called valve adjusting discs
and as low as £3.01 inc postage
search""
"FORD VALVE ADJUSTING DISCS"
or to get hopefully quality
Valve Clearance Adjusting Disc Febi Bilstein ford
Postby metalworker0 » Mon Jun 19, 2023 6:10 pm
How did you get on ....you were last seen making out it was ground hog day ..is it still ground hog day :)
Postby sparkybandit » Fri Jun 23, 2023 2:05 am
everyday is groundhog day here :D
give you an update video soon
sparkybandit
Postby sparkybandit » Wed Jun 28, 2023 12:33 pm
sparkybandit
