Driver seat foam re construction idea/s
Postby Shaun.Lovelock » Tue Jan 09, 2024 11:35 pm
Noticed the drivers seat in my connect limited this evening wasn’t right then I looked underneath and noticed that the centre piece of foam has split so when I sit down the foam pushes through the metal support! Any ideas on how to re support the foam permanently if anyone else has had the same issue?! Thanks
Shaun.Lovelock
