by Shaun.Lovelock » Sun Jan 07, 2024 9:51 am
Yesterday I removed a hardwired dash cam in a connect that I recently purchased the cable that connected to the dash cam mount on the windscreen was routed under the original plastic rain sensor trim, but it doesn’t seem to sit flat against the windscreen now the dash cam cable has been removed it clips into the top section ok but at the bottom there’s nothing for the trim to clip into so there’s a 5mm gap around the windscreen and the plastic trim cover!? Thanks
