ok so, van is currently a 2011 connect however the wet belt failed on this a while back and i had the older chain engine fitted instead along with the gearbox from my old 2007 connect which was the mk1 focus gearbox. had a quick search on the forum to remind myself on the correct box as its been awhile and would like any guru's to confirm im looking at the correct box to buy as the diff bearing is failing.
FORD FOCUS MK1 1.8 TDDi 5 SPEED GEARBOX 2S4R-7002-MA MB MC 1486262 2001-2005
thx again
