Hi,
I have just joined the forum as I am having trouble with my 2005 Transit Connect 1.8 tddi.
I bump started it a few times as I thought the battery was going, it wouldnt start/turnover and the lights would dim when turning the key. It then wouldn't bump on the third attempt and there seemed to be more resistance. Ibassumed the starter was stuck in. I had to get it recovered the recovery guy said the battery was good and it was probably the starter.
It had to be rolled to the recovery vehicle and the bottom of the front bumper impacted on the road surface quite hard.
I have changed the starter and it now cranks but wont start.
I have checked there is fuel at the injectors, and I have replaced the battery as it did go flat a while ago.
It does run briefly with easy start.
I have paid for forscan as the cheap handheld reader would only get code p1000. I now have codes:
P1564 fuel injection pump reduced fuel mode request
P1664 fuel injection pump malfunction
I have also read live data from the fuel pump and get some error codes, and what seem to be weird readings to me.
The supply voltage pid shows voltage spikes of 700v, then 0v then 600v etc.
The status pids also show some faults, but these are intermittent. After a few voltage spikes and drops:
Status 4 Angle of rotation sensor (current) which starts as showing a fault, switches to no fault.
At that time Angle of rotation sensor (permanent) switches from no fault to fault. As do idle switch level, solenoid voltage too high/low (current)and temperature too high.
Obd rpm pid does give a reading of over 200 rpm. Does this use the crank sensor data and does that mean the crank sensor is okay?
The grounds look a bit rusty but when I check resistance with a multi meter I get less than 1 ohm for everything I have checked so far.
Although it was above 1 when I checked battery negative to the steel by the fusebox behind the glove compartment.
I am wondering what the issues might be.
It's possible there is damage to looms around the front bumper and fan from the impact when being recovered.
I've read that bumping can cause timing to go out. The pid for Begining of injection point not recognized shows no fault. Does this indicate timing is okay?
Could I have caused damage firring the starter, or is it possible to wore it up wrong?
Could trying to start with a broken starter have fries some electrics?
I'm no mechanic, but am mechanically minded. Any advice on what to look at would be really appreciated.
Sorry for all the questions!
Rob
