I tried putting tape over the sensors in the front which works most of the time however, since I am living in the van full-time, it will sometimes go off in the middle of the night when I will be turning in bed which as you can imagine is rather annoying.
Is there also a sensor in the back/van section? I remember just stuffing something in behind the insulation so I guess that was one too. A round black thing.
I have ended up just not locking the van which is less than ideal.
Can I just disable it completely? Is it just a case of finding the right fuse and removing it? Someone on another forum said you should not do that as some vans the whole electrical system will break if it notices the alarm is disabled. Is this true of the transit connect, specifically 2007?
Ideally there would be a way to disable it when I am sleeping in there and re-enable for when I am actually away from the van and have parked it but totally disabling would be fine. Are alarms really a deterrent these days to thieves? I don't know. Could I just put a switch on one of the alarm system's wires? Just have to find where is it wired up.
