The open door warning chime is going off intermittently but fairly continuously on my 2010 Transit Connect. It seems worse when turning right or hitting large bumps. I suspect the driver's side door but it could be any.
While it could be a shorting wire, I suspect that it's something mechanical with the sensor. I saw a video on Youtube where they put a little felt furniture pad on the sliding door and that fixed the problem. It didn't fix the problem for me. Is there a similar 'cludge' for the swinging doors (driver, passenger & rear)? Or any other ideas of how to disable the chime? It's driving me bonkers.
Thank you!
