Hello All.
I'm after some help please. I have a Transit connect 2007 1.8 TDCI. over the last few weeks the car has developed a fault where it seems it goes into limp mode when the car gets hot. It won't Rev past 1Rpm when it's at its worse and it starts smoking white smoke.
Once the car is cool then it drives normal until it gets Warm and same problem persists.
I've had the EGR blanked and Turbo with manifold changed. Also one of the hose was split this was replaced. however the problem still persists. Anybody else has this issue and how did you overcome. Any help would be great.
